Question about Home
Triton 300si wireless shower problem - Shower motor is working but the low presure sign is flashing but all other water pressure is normal. Water was coming out but going hot and cold but has now stopped all together. Cheers
  • 700 Answers
Check inlet water first for consistency, if flow is fine and pump is working correctly, then check non-return valve on your pump outlet.
if these check correctly, check electrical side, if flow to heating element is constant, if that is interrupted, i am afraid that motherboard on your unit may be faulty,
you have then only two choices, dismantle the unit and check all wiring and component or get unit to repair centre or call plumber... or eventually replace unit by yourself.
please be aware that mendling in electrical circuit is dangerous! fully disconnect from power before you remove the covers!!
please be aware that before you attempt to repair electrical or plumbing gear you need to cut off power or water supply to the unit in full, they do not mix very well... :-)
Posted on Jul 30, 2010
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Triton t300si shower low pressure problem
there is a fine inlet filter on the plastic pipe,remove and wash under tap pressure
Feb 26, 2013 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Shower keeps coming up with low pressure and water goes
think ur presure redusing velve [prv] is durty and ur hot and cold water is not balenced presure . the prv is 90% of time located in 1m radius on cold water seply to geyser look for a curtrage , unscrew clean out and put back. will fix the problem
Plz rate my advice
Jun 01, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Shower pressure.
Hi chicken69
I'm Harvey the Master Plumber.
You want to know why the presssure on your triton t80i shower has dropped by half?
It is very possible that some debrie has come up in the water and is partially clogging the shower. For this you would have to turn the water off and dissassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
433 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
