Question about Craftsman Garden
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
Same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Posted on Oct 19, 2010
  • Stan2527 Mar 31, 2011
    My piston stop (#4357) is "toasted". Sears parts claims impossible to get part. Per Sears -Manufacturer was Soto P Colovis company. Is there another possibility?
  • Kenneth Case
    Kenneth Case Jan 15, 2013
    stan2527 did you ever find anything
    New Friend:
Go to DeWalt/Porter Cable Outlet Store. Item number 886113. Works great. Thank you Sears for all of your help. I will never by another power tool from Sears again. Their Customer Service sucks.
Posted on Apr 10, 2013
  • R. Gray Apr 10, 2013
    New Friend:
Would any of you know the part number for an alternative craftsman deflector 20904.00
Posted on Dec 26, 2015
I had the same problem with my finish nailer. Just wanted to say thanks and it worked great.
Posted on May 14, 2013
I need a piston stop for a craftsman finish nailer part number4573.00 sears states they are not being made anymore do other nail guns use the same part
I am not familiar with nail guns but if there is a place to put a piston stop, can you use a piece of rope instead? I have used rope to stop the piston on chainsaws I have fixed where my piston stop tools wouldn't work
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 14, 2013 | Craftsman Garden
Need piston stop for a craftman model 351.183210
It looks an awful lot like a Porter Cable FN250A so you may want to try a piston stop from that tool. Here is a link for the PC.
PC FN250A parts diagram.
Aug 15, 2012 | Air Tools & Compressors
Finishing nailer wont fire
Make sure that you do not have a Jambed nail. Open front quick release removed damaged nail and push driver back up with small screwdriver. Make sure to check date on fuel cell befor firing. Good luck
Apr 09, 2012 | RTO Paslode 902000 IM250 Ii Cordless 16...
My bostich1664FN was working fine,then it stopped shooting nails.How can I troubleshoot this problem. Thanks John
Here are some easy tests.
Assuming that the gun is firing normally however no nails are ejected. Remove the head of the gun and check if the piston is not returning to top of cylinder (piston needs to return to top for nail to enter into positon under the driver). Piston not returning to top indicates, bent driver or worn oring on piston. Repair /replace as needed. If driver/oring looks good, pull out the cylinder and look for check band in place around series of holes on lower part of cylinder and bumper should not be cracked. Lube all orings with silicone paste lube. Good luck
Sep 06, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
I have a craftsman 16 gauge finish nailer, model 918441. it is not advancing the nails. not certain how to adjust. cannot find the manual. is the manual available on line?
Assuming that the nails are correct for gun (16g nails measure .055) and feeder is actually applying pressure to nails (feel spring pressure as you close clip), most likely problem is driver is not returning to top of cylinder. This is caused by low pressure to gun, bent driver, lower bumper missing pieces/cracked, worn oring on piston or lack of lubrication. Remove cylinder and examine condition of lower bumper, replace if broken/cracked; check outer cylinder for check valve in place (usually small band or oring covering series of ventholes) ; replace piston oring as needed, make sure driver not bent. Parts available at sears web site. Good luck
Sep 08, 2010 | Craftsman Tools & Hardware - Others
Craftsman nailer striker is stuck down after firing.
my porter cable nailer does the same thing. what is the problem
Jan 26, 2010 | Air Tools & Compressors
Need a users manual for a craftsman in-line 15 gauge finish nailer model # 181770. I am having trouble finding the finishing nails for this model #. I looked on the craftsman website and it shows 1 1/2 in....
go to www.manualnguide.com i looked and they have the guide there you can download for free. Any nails will work as long as you get 15 gauge nails only thing that matters is whether or not they are straight or angled
Hope this helps
Nov 12, 2009 | Air Tools & Compressors
My Sears Craftsman 18 gauge brad nailer won't nail unless I release the nails from supply, remove the front cover, slide up I think it's called a striker, then replace the cover, re-set the supply and...
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Oct 12, 2009 | Tools & Hardware - Others
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Garden Logo
935 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
