Question about Sebo K1 airbelt Bagged Canister Vacuum
How to fix sebo air belt k1 hoover
I'M JUST TRYING TO OPEN THE HOOVER TO FIX IT. HOW CAN I DO IT?
    Champion:
  • 274 Answers
What is the problem first, I need to know before I can help
Posted on Jul 29, 2010
Hoover does not 'hoover' properly
If it has a power nozzle you should replace the belt.
Dec 18, 2013 | Miele Blue Moon Bagged Canister Vacuum
My sebo x4 bagged hoover is losing power, what could the problem be
Is it a Sebo , or is it a Hoover. It can't be both . "losing power" ??? Motor comes on and off ? or stops picking up ? Be more specific please.
Oct 20, 2013 | Sebo X4 Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Roatary brushes do not turn on my hoover steam vac dualy
the machine uses an air powered turbine which typically rusts and then locks itself up Ive been able to fix it in the past but its best to replace the whole assembly
Jul 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
Sebo Airbelt K1 Electrical Problem
Remove the belt or seal that goes around it, there are some clips to take out, then it will separate.
Mar 03, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo airbelt k1
No screws under the castors. There is 3 case clips, the bumper hides them, maybe this picture will help:
Feb 06, 2008 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo K1 airbelt Bagged Canister Vacuum Logo
220 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
