Question about Video Game Consoles & Games
PS3 error code 8001050f-80010514 and 80028f22,, I took a blueray eye out of a working PS3 to test, it can now see the disk, but will frezzup if i try to play it.
  • 2,272 Answers
This all error codes can be reset by the procedure.But if the lens is removed and there is a freezing problem then its a problem of lens alignment or the lens spinning motor is got loose or weak check it. click this link for the reset procedure:--For this errors. http://www.youtube.com/watch?v=1CJ9Q8bG-0s&feature=player_embedded -------- But if there is lens alignment or lens motor problem then it needs to be checked and repaired to resolved the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 29, 2010
    President:
  • 1,194 Answers
For error 8001050f :-
Step 1: go to Settings / System Settings / Restore default settings.
you will be asked if you really want restore the default settings. Confirm.
After that, press the X button to restart the PS3 console.
Step 2: when booting normally configure your PS3, including the date and your internet settings.
Step 3: Go to Game / Trophies / Options / Sync with server
Step 4: Log into your account and psn confirm the synchronization of trophies.
Step 5: Restart your PS3.
Step 6: Place your newest game in the console (in my case I put the Modern Warfare 2)
Step 7: Select the game. will be asked to start a game update. Confirm.
Step 8: If all goes well, All games will start normally.
For error 80010514:-
Step 1.Start with having the system in standby (redlight is on)
Step 2. Hold the power button down; the system will turn on and turn off once again.
Step 3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
Step 4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that that will fix blu-ray drive is option 3: RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
If you still have the same problem then you better contact Sony.
Thanks for using Fixya.
Won't play a blue ray disc
The blueray eye is out. You will need a new blueray player. The only problem with that is the ps3 will only respond with the orginal parts it came with. ( i.e. motherboard blueray player ) So the best bet is to buy a broken blueray player and take the eye out and replace it with yours just the eye not the whole thing.
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
PS3 Blueray drive,, Both blue and red LED's work, but it will not read a blueray disk, At first it spins fine and looks good,, but then the disk slows down and the eye jumps back down, at this piont it...
If this solution am providing you now did not solve the problem, i will advice you format or get a new drive.
Make sure PS3 is connected via correct cable.
Power Off the PS3 via the power switch in back and power back on with switch. Hold Power Button on the Front until you hear 3 beeps. Your ps3 should automatically reset.
Take care.
Jul 29, 2010 | Video Game Consoles & Games
PS3 error code : 8001050F appears when attempting to sign in to playstation network
yes it is hard but u have to format your utility disk for about 2 hours then set the time to now and you should be ok
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Error code 8001050f
its a calander error, it only affects older rounder ps3 models, its also affecting trophys and downloaded content. they are working to fix this problem. this problem has come about becouse of the leap year, it cant change the date from 28th of feb to 1st of march
How do i fix a ps3 error code 8001050f ??
There is a major problem right across the board at this very moment with the PSN Network, whereby some consoles are not synching properly and causing problems like you describe.
For a full breakdown please see this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
PS3 error code 8001050F? How to fix?
Sony Network is experiencing sporadic outages in certain areas today.
It may be a scheduled system upgrade or maintenance - but be assured you are not the only one facing this issue.
No UP time has been announced by Sony - they are working to get the system up and running as soon as possible.
The problem is not on your end.
Keep trying to connect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
PS# console error code 8001050f
PSN is doing repairs ATM there is nothing you can do but wait
Error Code 8001050F wont allow me to play my games.
.......... There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and yes, we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation
Ps3 turns on but does not reconize disk
that means the laser eye is dirty it needs cleaned try running a lens cleaner disk through it. that should fix your problem
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
2,433 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
