Question about Windchaser PACR10 Portable Air Conditioner
I keep getting error code e3 and e4???... what should i do?
PORTABLE AIR CONDITION ERROR 3E
Posted on Aug 05, 2010
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My SoleusAir portable air conditioner has an "e4" code.
Here are the SoleusAir error codes...
e2 Room temperature outside of working range of unit (too cold).
e3 Faulty coils - Repairs needed.
e4 Internal frost in the unit - Defrost.
e5 General failure - repair needed.
e7 Reservoir full - Empty the reservoir.
If the unit is freezing up (frosting) you may want to check (clean / replace) the filters.
Sep 13, 2014 | Heating & Cooling
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Jan 29, 2009 | Omron Body Fat Analyzer from
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Windchaser PACR10 Portable Air Conditioner Logo
856 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
