Question about Sirius Starmate ST2 Satellite Radio Receiver
Distorted sound Loud static sound has started. You can hear the program playing, but with a lot of static. When it started all I had to do was touch the unit and it would clear up. Then it got worse and if you pressed the unit it stopped. Now I can't get it to work at all, sometimes if you touch it again all you get is static, then it cuts out completely.
  • 5 more comments
  • Anonymous May 02, 2008
    My back light went out and now the transmitter seems to have a hard time transmitting. Tons of static!
  • echyone Jun 06, 2008
    I have the exact same problem. I it got so bad that no amount or squeezing would stop the static. Eventually I cracked the LCD and now I have to buy a new one.
  • xytqw Jul 08, 2008
    Distorted sound started suddenly after 2 + years of flawless performance. Just touching the unit will invoke the distortion. A static sound over the regular programming. Squeezing unit gets relief sometimes.
  • Anonymous Jul 23, 2008
    I have exactly the same problem. I used to be able to squeeze the receiver and base together to hear the sound, but now all I get is loud static. It worked without any problems until this, and I have no idea what to do. I'm hoping someone has a solution before I go out and buy another receiver.
  • toddarmpit Sep 03, 2008
    I also have the same problem! It also worked flawlessy for about 2 and a half years. PLEASE, somebody, Help!
  • Anonymous Oct 17, 2008
    My st2 worked for 3 years and now has static. Squeezing helps until I hit a bump.
  • netsfan Mar 17, 2009
    I had a similar problem. Got my unit about 3 years ago. All of a sudden I get intermittent static. Touching it sometimes helps, but then the static comes back shortly after. Squeezing it seems to work, but it's not so easy to do while driving.....
I have had this problem also. While I haven't completely fixed it I have figured out the root of the issue. Within this unit there are two circuit boards. Between the two boards is a white connection. It appears this connection becomes loose or is susceptable to the heat that is generated from the unit. I've tried teasing out the pins within the connection to see if they can get a better fit together. This will work for a little while but then the static returns. I'll post back if I come up with a final solution to this problem.
Posted on Jul 13, 2009
  • JaBurd Jul 19, 2009
    Ok, here is what I have done to remedy this issue: Remove the 4 screws from the back of this unit. Take your fingernail or small plastic point and carefully seperate the back black bezel from the front silver bezel. Un-solder the FM transmitter antenna, or bend the antenna as you pull the two circuit boards out of the back bezel. The issue is caused by the connector that sits between the two circuit boards. It is located in the bottom right of the unit right behind the 0 key and down arrow. Manipulate the two boards by spreading them until the static goes away (unit plugged in and running). Once you get the connection to a point where it is no longer making static take some super glue and glue the connector into that position. So far this is working for me, and I don't have to replace the unit.
  • PakChoi Jun 10, 2014
    The only problem with this fix is that you can no longer separate the two boards which makes the connectors inaccessible for any future repairs..
I also have the same problem after flawless reception for 3 years. Squeezing helps until Ihit a bump. Please help.
Posted on Oct 17, 2008
Loud noise when trying to set to record or to play the noise is like loud static and I have to turn off both the TV and the DVD player to get it to stop the noise  I suspect it is the control
When you hear the static, turn power off and then back on again and it will go away. Some players have been know to do that. It is a problem with the programming. Just turn power off and right back on again and it should be fine.
Aug 06, 2009 | Televison & Video
Sony KV32FS100. Loud static sound
Check the wires one might be touching another..
Jul 30, 2009 | Televison & Video
Extreme distortion/static in music.
you might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
May 27, 2009 | Phase Linear PLC 400
Static noise/no sound from ipod touch
Sounds like you just need the ipods headphone jack replaced.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod repairs.
Mar 16, 2009 | Apple iPod touch
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
IPOD TOUCH
same thing happened to me. your probably not plugging the headphones in all the way.
Sep 07, 2008 | Apple iPod touch
Sound issues
i also have a sound issue, when i connect the speakers to the computer i just get a loud noise and i cant hear the cd i'm playing
Apr 25, 2008 | Dell Dimension 2400 PC Desktop
Zen vision m not playing properly
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/
Nov 25, 2007 | Creative Labs Zen Touch MP3 Player
Sirius Starmate ST2 Satellite Radio Receiver Logo
421 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
