Question about Nokia 5230 Cell Phone
Does the nokia 5230 have a countdown timer on it
  • 37 Answers
No but there are plenty of free countdown timers to download and install, for example - http://www.getjar.com/mobile/28927/quick-timer-for-nokia-5230/
Posted on Jul 29, 2010
How do you connect the wires to utilitech countdown timer 0140599
Open following link to identify Utilitec countdown timer with red, black, white, and green wires:
http://waterheatertimer.org/images/Utilitec-156020-LW60415-countdown.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#Ei
If this is not your timer, then add a comment and describe timer in detail along with what you know about timer for best answer.
Open following link for wiring instructions:
http://waterheatertimer.org/Programmable.html#wire
Oct 01, 2011 | Hardware & Accessories
How to unlock nokia 5230
You can get the Unlock code from service provider and Unlock it...they wil help You in unlocking,
Aug 07, 2011 | Nokia 5230 Cell Phone
Programming to command other switches
Question is not clear.
Add a comment and say specifically what timer you have and what type of switch(es) you want to control, and add what voltage you are working with and what color wires you have.
You posted under Leviton 6230 30-minute countdown timer.
Generally, a countdown timer is not considered a programmable timer since the countdown program is already inside the timer.
With countdown timer, you push a button that turns circuit ON, and after countdown expires, the circuit turns OFF.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
Countdown timer can easily switch a contactor ON, and then turn it off after countdown expires.
http://waterheatertimer.org/H230A.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Leviton 6230M Decora Four Preset...
Manual operated switch which can be set time for automatic off without electric required for switch
You want a spring-powered countdown timer.
There are no battery-operated countdown timers.
Open following link for selection, plus horsepower ratings:
Woods 59700 series and Intermatic FD and FF series are rated 1 HP.
Different brands of spring-wound countdown timers can be found at any home center and are usually located with switches or timers. Home Depot carries GE brand.
Upvote the help.
May 13, 2011 | Hardware & Accessories
I wouold like an outlet timer that I can press 'go' and the outlet is on for 15 minutes then outlet turns off. Is there such a thing?? So the curling iron is on 15 minutes then off when i forget to unplug
Option 1: Buy ordinary 15 minute countdown timer installed in place of a switch, and then wired to an outlet.
Option 2: Programmable plug-in timer with countdown option. 1800Watts max so double-check watt rating of iron. If this is residential iron, then it will be safe.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#plug-in
http://waterheatertimer.org/UPM-timers-and-manuals.html
SE11P
ET150
ET170
Westek TE05WHBL
I need some up-votes for all the hard work I do for folks.
May 03, 2011 | Woods Hardware & Accessories
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Program a timer
You posted under Paragon 2606 Panel-mount countdown timer.
If this is not your timer, add a comment.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
2600 series is mechanical interval timer.
26006-00 can handle 10 amp loads.
Interval timer is a countdown timer that keeps Load turned on for set amount of time.
You set the time by rotating dial
To start timer, Rotate dial from 1 minute to 30 minute.
Rotating dial turns on Load and begins countdown.
Timer turns OFF Load after set amount of time expires.
Nov 26, 2010 | Electric Paragon 2606-00 Timer
How do I set the time on the 61048 SUNBEAM DIGITAL TIMER
This is a countdown-type timer, for precise cooking times, etc. Press hour and minute buttons to set time.
Press start button to begin countdown.
Press hour and minute buttons same time to reset timer.
Timer beeps each 5 and 10 minute intervals during countdown.
This timer does not connect to any electrical device, has a magnet on back, and has internal battery operated.
For large image of timer:
http://www.oneida.com/oneida-digital-clock-timer.html?utm_source=Shopping.com
Nov 06, 2010 | Sunbeam 6 Robinson Home Digital Timer
Nokia 5230 Cell Phone Logo
1,340 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
