Question about Mag Innovision lt456s 14" Flat Panel LCD Monitor
Monitor Message = "No Signal"
I was given a Mag Innovision LT456 flat screen. (a) I connected it to a Compaq computer. The message "no signal" flashes five times and goes away. The screen is black. (b) I connected it to a Dell Demension computer and get the message "Mode Not Supported." The message stays on the screen.
By the way, I have two regular monitors that work fine with these computers.
Any help
Albert in Chicago
  • elkneller Oct 27, 2008
    I have the same problem with the same model monitor, but connected to a Toshiba running xp
  • 102 Answers
See i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Posted on May 17, 2009
Won't work.
You have to press the fn+f5 I think in your laptop. It is the same when you are using a projector.
Nov 11, 2013 | Mag Innovision LT576s 15" Flat Panel LCD...
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
No signal on monitor
Dear Brother,
  • Check your Monitor Cable
  • Check your Cables PINS Broken/Damaged
  • Check Properly Plugged in the Cable to both PC and Monitor
  • Check your Display Card
  • Check your Motherboard Connection With Display Card
  • Unplug the Cables end From PC and Monitor
  • Unplug From Power too and Then Correctly Plug in
  • Connect CPU to another PC(for making Sure problem is for Monitor)
Your Problem can be Solved...... Hope This HELPED YOU Thanks For Using FixYa
Apr 06, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I just moved and my monitor is saying it has no signal. Everything is hooked up the way it was. Whats wrong?
Go inside and move the card to another slot. If that doesn't work, take the monitor to a friends house and confirm the monitor is still good.
Aug 05, 2009 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
LT582s Mag Innovision
It all depends if the Mag has been used before on the same system or it is a new installation or on a different computer.
  • If it is connected to an existing set-up and has been used previously, then possibly it is the computer's video card/memory or just not booting. Alternately, it could be the video interface/main board of the monitor or even possibly the cable;
  • If it is just being installed on a known good computer, then it could be that the screen resolution and/or the screen refresh rate of the display properties of the computer needs to be lowered down.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Innovision LT765b 17 in. Flat Panel LCD Monitor
Well, sure it fixable... but not so easy to find a AD board online. Only manufacturer carried this part... If you want you can contact them if they still have a refurbished parts laid around....
Jul 26, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Aug 30, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
260 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
