Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
My KSRS27 has a new fan noise that seems to be in the area of the top of the freezer? any suggestions. it is louder at some times than others. It is not the fan at the bottom or the compressor.
    President:
  • 670 Answers
It might be the ice maker motor. Try turning off the ice maker and see if that stops the noise.
Posted on Jul 29, 2010
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
My fridge is making a god awful noise... it's still cooling, but the noise is off and on and each time it comes back it's louder and louder.... any suggestions??
When do you hear the noise? What is the refrigerator doing when the noise comes back?
If it is when the compressor kicks on, I would check the mounting brackets for the compressor and make sure they are tight.
If it is a clatter then I would check the colling fans (top and bottom and make sure the blades are striking something.
Where you say it is getting louder and louder, I would check for ice buildup on the evaporator fan in the freezer section.
Jun 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
JennAir JFC2087HRS makes creaking noises like an old door or someone's stomach growling all day. Now noticed that ice maker not working. Suggestions on how to fix?
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Apr 01, 2010 | Jenn-Air JFC2087HRS Side by Side...
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Unusual fan noise
sounds like you need a new fan motor or blade
Jun 03, 2008 | Amana ARB8057CSL Bottom Freezer...
KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
50 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
