Question about Northstar Pressure Washer 3000 PSI
I have a model 157818E Pressure Washer. Ineed a cap and other parts but I can not find a parts picture to see the parts. Can you help me?
  • 10,865 Answers
Hi. this is the source I use http://www.pressure-washer-parts.com/
Joe
Posted on Jul 29, 2010
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
Ineed a part for Siemens washer wfxd5200uc. It is the plastic piece that acts as an intake for HOT water and connects to the hose. Need a supplier and a "pull apart" picture to make sure I am...
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can identify and order, possibly discussing over the 'phone. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Mar 23, 2011 | Siemens Washing Machines
Striped pressure outlet connection
Here is a link to a company that sells stuff for your machine.
link
Rate this if it helps you.
Jan 11, 2010 | Coleman Pressure Washer PW0881800
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Lance
Here is a link where you can look up your exact model and replacement parts from coleman...
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts
Looks like your model may be out of production though so here's a generic kit that will 99% work with your washer...
http://www.silverbin.com/FAIP-PowerWasher-Universal-Pressure-Washer-Gutter/A/B000EEQ9KM.htm
Hope that helps...
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Whirlpool duet washer tub bearing
wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Northstar Pressure Washer 3000 PSI Logo
127 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
