Question about Yamaha HTR-6130 Receiver
HTR-6130 low volume
The sound from my Yamaha HTR-6130 is coming very low.
I should be able to confortably watch at -40db (since it goes from -80db to +12db) however, the only time i get normal sound is at around 0db.
What is causing this problem?
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
mlapres
  • 757 Answers
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
smarthome2
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
  • 50 Answers
SOURCE: All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Posted on Jul 05, 2009
  • 9 Answers
SOURCE: Bought a Yamaha HTR-6130 doesnt
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Posted on Sep 09, 2009
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
Receiver displays Dolby Digital while watching TV, but only 2 front speakers work. This is the case on only certain TV stations. I have a Yamaha HTR-6130
Depending upon transmmission bit rate, if the transmission is > then 6130 bit rate it will automatically change to 'STRAIGHT' mode and in this mode only two front speaker will work.
Oct 15, 2009 | Yamaha HTR-6130 Receiver
Jul 04, 2009 | Yamaha HTR-6130 Receiver
I have a Yamaha HTR-6130 connected to a Samsung 550 plasma tv. I find the speaking sound in movies and tv programing to be too low relative to other background sounds. Any way to raise the relative...
If your running the receiver in 5.1 using a center channel, go into the main menu of the receiver and select "speaker settings" toggle to "center channel" and adjust the gain to taste. If you need more help, post a comment and I can help you some more
Jun 25, 2009 | Yamaha HTR-6130 Receiver
Trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
May 24, 2009 | Yamaha HTR-6130 Receiver
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Yamaha HTR-6130 Receiver Logo
82 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
