Question about Xerox WorkCentre M20i All-In-One Laser Printer
The fax shows a messages saying "open heat error"
I HAVE A XEROX M20I COPIER WHICH IS GIVING AN ERROR MESSAGE: OPEN HEAT ERROR" I TRIED TO FIX BY THE HELP THROUGH THE XEROX ON LINE HELP SITE BY UNPLUGGING AND RECONNECTING THE MACHINE BUT MESSAGE STILL PERSISTS. ANY SUGGESTION BY THE EXPERTS REGARDING THIS PROBLEM? THANKS!
  • 239 Answers
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Posted on Aug 10, 2010
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
LSU error displayed on Xerox M20i
LSU stands for Laser Scanner Unit. It comes up only if you are trying to access scanner services like scanning a document, using fax or simple scanning.
If it's coming continuously you might need to check connectors within the scanner. Best way is to call a technician from Xerox or take it to their store.
Jun 21, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox work center 7132 will not boot up. error code (092-310). It says shut down printer and turn it back on. but i did that cuople of times still the same error code. it says contact service if error...
Try to unplug the device directly from the socket wall and leave it for 5min. Plug in again. If message still occour it could be related to 2 reasons.
1. Sensor problem leading to "ghost" message -- require eng.
2. Toner replacement also causes this message.
Even if you do couple of boot routines you might want to have someone onsite to have a look at it. It might require parts.
May 04, 2010 | Xerox WorkCentre M20i All-In-One Laser...
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Open Heat Error
it is a fuser related problem . check thermostat at fuser
Dec 10, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Cannot fax using my Workcentre M20i
The machine itself can not give that message. You have some tye of phone line issue.
Feb 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Jun 19, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
