Question about Kitchen Ranges
I have a Whirpool Gas dryer. Model # TGDX640pq0. Dryer Was on and not heating. After reading on it alot i cleaned out the outside vent inside the dryer in the ducts by blower , pretty much everywhere. Used the multimeter on all the components including the 2 coils and all showed continuity . After starting the dryer back up On timed dry with an empty drum everything worked fine looked in side peep hole on bottom left of dryer flame and sensor were working turning on and off properly. I then tried auto dry and the flame went on and after shutting off 5-10 mins later flame didnt come back on and ignited and sensor worked fine. I tried timed dry immediately after and then the flame on it also didnt work . The timer on auto dry doesnt move and i am completely lost . Can anyone please tell me whats wrong with my dryer.???
fridgetech
  • 473 Answers
SOURCE: Hotpoint Gas oven doesn't light
Sounds like the oven ignitor is weak.  If everything else is working it must be a bad ignitor.  These are usually easy to replace and can expect to pay $70-$100 for the part.  Check to see if it glows when in bake mode first.  If it does then replace the ignitor.  You can look at the ignitor,  when not on, if it is white-ish then it needs replace or if it doesn't have a full glow, can compare to broil ignitor, then it needs replaced.  Let me know if you have further questions.
Posted on Oct 13, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
SOURCE: ge spectra gas stove top not lighting
th to replaceere is also an electronic ignitor in the back of the stove that sends the spark to the burners, if they light with a match , then I would check out the back for a little black box
Posted on Oct 24, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
The dryer does not heart
is it gas or electric?what's the model number?if you checked the thermal fuse located on the blower wheel housing and that's ok,check the heating element with a meter,if it's gas you have to read out the ignitor,the sensor and the gas coils with a meter,if it's gas and you have parcial heat change out the gas coils,did you check the thermal fuse part 3392519 or on some dryers it's a 3390719 with a meter,if you did you have to remove one of the wires to get a true reading on anything you're reading out,also unplug the dryer before you check these things,also when you clean out the dryer you gotta take off the duct that the lint filter slides into and vac out the inside of the dryer,if the vent line is long,i use a leaf blower to clean out the line,remove the line from the dryer and the wall,stick the blower in the hole in the wall and blow the line out from the wall to the outside hood and make sure nothing is blocking the hood like a cage,some hoods come with a cage so animals can't crawl up the line,if you have this you gotta clean the cage every month,if you need more help send model number and if it's gas or electric
Dec 19, 2009 | Kenmore Dryers
Hi, i have a homebrand dryer. Model: TD50-89S. Without asking first,my son transferred washing to dryer. Unfortunately, there was alot of white fluff all over washing and he assumed the dryer could take...
Your duct work is probably clogged with the fluff, which will not allow the air to flow though like it should. When that happens, the heat builds up on the cabinet and the heat sensor shuts down the heat. Its an easy fix, it this is the case. Just remove the duct from the dryer, clean it out, clean out the fluff from the dryer duct connection, then go outside and inspect the outside dryer vent for clogs. Make sure the flapper is working on the outside vent as well. Good luck!
Oct 26, 2009 | Whirlpool LER7646E Dryer
My dryer Whirpool model LGR4434AQ0 don't heat air in cycle. What it can be?
Hello.
Most of the time, the problem is:
1. a plugged vent system.
2. broken heating elements or
3. a bad thermostat.
To check the venting system, turn the machine on and check for a strong air flow where the dryer exits the house, outside. If there is weak or no air flow, you may have an obstruction in the ducting, at the drter, or at the louvered vent in the wall to the outside. Unplug the dryer and remove the duct. Holding it like a "U", take it outside and shake it out. Look ate the wall vent; clean as necessary. Look into the dryer exhaust, remove any debris found there. Pull the lint trap and inspect the cavity. Vacuum out any debris. Replace the ducting.
If this doesn't fix you. Check your heating elements. If you have an electrical test meter and know how to use it, gain access to your heating element terminals inside the back panel, and test for continuity. Replace any defective heating elements. They are readily available from any appliance parts supply house.
If this still doesn't solve your problem, test and/or replace the thermostat as required.
Hope this was useful to you!
--W/D--
Jul 14, 2009 | Whirlpool Dryers
Gas dryer runs but does not dry clothes
is there heat?
if not.. many possible issues
if yes, venting issue
check to see if your vent is clean
alot of lint likes to accumilate outside at the vent that blocks air.
the dryer vent should be no longer than 15' if rigid and 10' if flexible
May 26, 2009 | Whirlpool Dryers
I have a gas whirpool senseon dryer model number ggw9868kq0 that won't heat up all the time. The heating element lights up and then goes out 10 seconds later. The thermal fuse is good and I replaced the...
Hi, If the ignitor glows and then shuts off before you get a flame, then you will need to change the coils on the top of the gas valve. This is the most common problem with the gas dryer not heating consistant. Make sure your venting to the outside is cleaned out. A plugged went causes the coils to go back quicker.
I hope this helps and please let me knw if I can assist you further.
Thanks
Vic
May 11, 2009 | Whirlpool LGR5636L Gas Dryer
Amana dryer model #LG4309W doesn't heat up like it used to
you need to get a vent cleaning the recommend that you get one evey 6 months with a gas dryer.
Dec 10, 2008 | Amana ALG443RAW Gas Dryer
Draye heat work but not dry
check your exhaust vent hose inside and outside your hose you should have alot of air coming from the dryer to outside this is where Id start
Dec 30, 2007 | Maytag HYG2460AWW Gas Dryer
Gas dryer not drying properly
you would want to check the force of the air coming out of your vent at the outside.if this is not great.check to make sure your duct is not kinked or your lint screen is clean.if you have already done this.then you have an internal block in your dryer duct.you will need to call in your local tech.
Jun 03, 2007 | Whirlpool GGW9200L Gas Dryer
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
