Question about Uniden BC780XLT Base Scanner
Uniden 780xlt - I need a KNOB for the On/Off switch
Uniden 780xlt - I need a KNOB for the On/Off Volume switch. Uniden does not have any in stock. Where can I get the knob?
Mark.
2 Suggested Answers
tparsenault
  • 170 Answers
SOURCE: volume control inoperable
spray some tuner cleaner in the volume and rf gain pots and work them back and forth. Have you tried an external speaker to see if stock speaker is blown? Also improperly installed talk back can cause this
Posted on Dec 28, 2008
Why don't I have sound on uniden pc78ltw?
the knob that turns the radio on and off is the volume potentiaometer.turn it 1/2 wayopen.the next knob is the squelch maqke sure it is all the to the left.the next knob is the mic gain and the RF gain.Set the mic gain at 1/2 and the RF gain all the to the right.the next knob is the delta tune,set it 1/2 way the next knob is the calibration knob leave it alone.Now above those knobs are little switches .the third switch from the left is for CB/PA make sure its on CB. check the WX switch and make sure it not on a weather station. and finally the last switch to the right is called a dynamic squelch switch.Make sure it is down. with all said your radio should be on and you should be able to hear sound. If not ,take an external speaker and hook it to the external speaker plug in the back of the radio.If you hear something then you internal speaker is junk.replace it .
Sep 04, 2014 | Radio Communications
Need to replace volume potentiometer on BC-60 XLT scanner
make a trip to radio shack for a replacement volume control..
Feb 02, 2014 | Uniden Radio Communications
Bearcat 780xlt firmware 1.19 need to update due to rebanding
Take a look at radioreference dot com. Search for similar problems, or join up and post your problem there.
Oct 11, 2010 | Uniden BC780XLT Base Scanner
How to reset my uniden 780xlt scanner
There is no "soft" reset for the BC780XLT, and the following "hard" reset will erase all programmed data and return the scanner to its original factory settings.
- Power the scanner OFF.
- Press and hold the 2, 9, and MANUAL keys and power the scanner ON.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC780XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 30, 2010 | Radio Communications
How to progam a bearcat police scaner
To program known frequencies into your BC370CRS:
- Slide the MODE switch to the "Scanner" position.
- Press and hold the POWER button momentarily to power the scanner ON.
- Turn the SQUELCH knob slowly to the left until scanning stops and you hear a hissing noise.
- Turn the Volume level down to a comfortable level.
- Turn the SQUELCH knob to the right - slowly, until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 158.075).
- Press E (PGM).
You've just programmed channel 01. To contimue programming, press the up arrow to advance to channel 02, press HOLD, enter your frequency, etc.
When you're finished programming, press the SCAN key.
Need the manual for your scanner? You can download and print it here:
http://www.uniden.com/pdf/BC370CRSom.pdf
For a comprehensive database of active frequencies in your area, visit:
Please contact me if you have any further scanner questions.
BillB
Jan 08, 2010 | Uniden BC370CRS Base Scanner
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Volume control inoperable
Dec 28, 2008 | Uniden Radio Communications
Need vfo knob for bc 780 uniden
If you want an original knob, check with Uniden. They may still have some in stock.
Apr 29, 2008 | Office Equipment & Supplies
Uniden BC780XLT Base Scanner Logo
200 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
