Question about Troy Bilt 5.5hp Self Propelled Mower
I have a troybilt self propelled model series 830. Yesterday we hit a stump and the blade bent and shut the lawnmower off. I recranked it and tried to recut when i noticed the blade was bent so i took it to the garage took it off and straigntned it and put it back on now the lawnmower is making a rattling noise and doesn't feel like it pulls correct.
    President:
  • 2,468 Answers
The blade is bent,replace it or you will ruin the engine,a new blade is much cheaper than a re-built engine and bearings,you bent it soooooo bad you can no longer even balance it, and if you continue it will destroy the engine if you have not done so already,this is the vibration you feel NOW
Posted on Jul 29, 2010
Self Propelled Gas Mower
with it off look under at blade probably bent and hitting frame replace blade if necessary
Aug 03, 2016 | Garden
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
My toro 20624 lost self-propelling after the blade hit a baseball
check for the belt being off pully under lawnmower
Sep 16, 2014 | Garden
Craftsman Self Propelled lawnmower will not allow me to pull starter cord out. Why? Very new mower 917.370433. Has oil and gas in it.
is your self porpelled engauged is your blade break dis engauged take the plug out can you turn blade by hand did you hit something check to see if blade is bent let me no what happens
Aug 31, 2014 | Garden
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
I hit something with , when i start the lawnmovers it goes crazy
The vibration is caused by a bent blade and/or a bent crankshaft. The first thing to do is to replace the blade to see if the vibration goes away. If it does not then you have a bent crankshaft. The higher rpm's is not normal but is probably caused by a timing problem caused by a sheared or partially sheared flywheel key.
Sep 14, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt 5.5hp Self Propelled Mower Logo
446 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
