Question about Stanley CT10C Heavy Duty Staple Gun/Cable Tacker
Is there a depth adjustment r tension adjustment
Is there a depth adjustment or tension adjustment on the Stanley CT10 stapler?
    Habit-Forming:
  • 37 Answers
As far as I can tell this unit does not have an adjustment. Normally such an adjustment would only be included on much more expensive and specialised units generally listed for professional use.
If you need more pressure then hitting the tack with a hammer is the general answer.
If you need less pressure, i.e. the tack is cutting through the insulation/wire you are tacking then a cushion may help.
Suggestions for cushion material include one or more layers of paper or a thin (e.g. 3mm) piece of neoprene foam. After tacking the wire in place the foam/paper can be removed almost completely to produce the desired result - a tacked wire with no damage.
Hope this helps. For more power I favour the Stanley PowerShot series: they are absolute brutes and shoot most variations of staples, tacks and nails.
Posted on Jul 31, 2010
How do you load a Stanley sharpshooter TRE500
You read the manual
Stanley TRE550 Owner Manual
Or watch the videos
Stanley electric stapler/brad nailer - YouTube
? 5:06
https://www.youtube.com/watch?v=Zbgt2UXpS-M
Dec 29, 2013 - Uploaded by Tindlez
How to load staples and brad nails in Stanley electric stapler model ... I actually did not feel the instructions ...
Stanley SharpShooter Manual Staple and Brad Gun review - YouTube
? 9:35
https://www.youtube.com/watch?v=jgnqwaWYaXQ Feb 22, 2015 - Uploaded by Unpack Guy
Stanley SharpShooter Manual Staple and Brad Gun review ... The stapler is a waste of money (I just got ...
Nov 08, 2017 | Stanley Tools & Hardware - Others
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
Will this stapler staple cardboard? Looking at using it for shipping products. I would fold single wall cardboard in half and staple it together. PS what size staples. Thanx
talk with your local office suppliers or good hard ware shop for longer staples for the machine
the problem you will have to consider is the length behind the staples that will restrict how far down the sides of the container you can staple
box and carton staplers are available on line , are foot operated and have considerable depth for the purpose of containers and boxes or there may be a local supplier that will have a machine better suited for what you want to do.
Sep 01, 2015 | Stanley BOSTITCH 00540 00540 AntiJam Extra...
I am having problems getting the staple to go all the way in -- recovering dining room chair seats. I have lost the manual -- does the dial with + and - have something to do with it? Stanley TRE500...
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
May 08, 2011 | Electric Stanley Tre500 Staple Gun /...
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Stanley Pneu Roof Stapler Troubleshooting
Sorry for the delayed response, I just found this one...
The issue with depth is usually one of 2 things:
1) Insufficient pressure (bad regulator on compressor or incorrect setting).
2) Bad seals within the gun.
When was the gun last serviced? Have you looked at the O-rings for any signs of damage? All it takes is a little leakage of pressure and the plunger won't have enough thrust to set the staple as expected.
Dan
Aug 27, 2008 | Stanley Pneu Roof Stapler
Stanley CT10C Heavy Duty Staple Gun/Cable Tacker Logo
317 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
