Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
When i turn on the jacuzzi, black pieces ( look like some kind of lining) comes out of the jets.
  • 33 Answers
Possibly some seals deteriorating.. check pump and connections..
Posted on Aug 02, 2010
Aqualux whirlpool tub how do I clean jets?
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Nov 02, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
We use our jacuzzi once every two weeks. Every time we get small black particles of debris of some sort that sticks to the side of the tub. What is the problem?
the problem is bacteria building up in the water lines once the water dries. You should be using a jet cleaning product to clean the water lines out before they dry.
We have several different good cleaners on our site that all work well at keeping bacteria out of your water lines.
You can click on the link below and it will show you what is available.
Jet cleaners
Feb 16, 2011 | Jacuzzi Home
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Black stuff comes out of the jets. why?
The black stuff is probably your dead skin and body filth. Fill up the tub with bleach solution and cycle for 15 minutes, once a month.
Oct 11, 2009 | Jacuzzi Home
Jacuzzi at higher elevation to swimming pool, water falls off jacuzzi when pool filter running (is designed to do this!!). currently air bubbles coming from one of the jets when pool and jacuzzi turned...
you probably have a check valve (back flow preventer) on the line that supplies water to the spa when the pool is filtering as normal. Your check valve may have some debris in it or the seal inside may have failed allowing the water to drain into the pool when the system is off. You should see a valve on the return line that splits off from the pool return line on your system. There are several different check valves on the market, some have a clear lid that you can inspect without taking it apart. Some of them cannot be taken apart. Your challenge will be to find the check valve, then try to check to see it debris may be holding it partly open or it the rubber seal inside is damaged or missing. I hope this helps.
Sep 23, 2009 | Pool & Spa
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
Feb 13, 2009 | Jacuzzi Diffuser, 1 1/2 - 3 Hp...
Trash come out of jets
Sounds like the hoses to the jets are the pump are breaking down and pieces coming off. Replace the bad hoze(s).
Feb 01, 2009 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Jacuzzi Leaking
you need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
Dec 09, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
116 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
