I HAVE PLUGGED IT IN FOR THE FIRST TIME AND THE ATTENTION LIGHT IS FLASHING. WHAT IS THE PROBLEM?
  • 906 Answers
Good day Sir, May I know brand and model of your printer so i can tell if it is a problem. and also the blinking of light if it is slow or fast.
thank you.
Posted on Jul 30, 2010
Does the 2006 scion tc have some sort of code where the check engine light flashes to indicate a specific problem?
I always say,"if the light is solid, it's not much to worry about, but if it flashes, it's time to get it checked. But some vehicles do have a flashing light when codes are being pulled. But I don't think this is your case. I think it's telling you to get it checked by flashing and keeping your attention to the problem.
Dec 15, 2011 | 2006 Scion tC
HP2550 problem:The attention light, the ready light and the go light stay on (not flashing). When I hold the Go and Cancel button down, the attention light and the ready light stay on (secondary light...
According to your "secondary" light pattern your printer has a Carousel motor error.
You've already power cycled it to no avail.
The next step is to get the motor replaced.
Sorry, I know that you didn't want to hear that.
Apr 06, 2011 | HP LaserJet 2550L Printer
Over drive light always blink and trans wont shift in to 3,4 gear
Hi Rod, Your vehicle needs to be taken to a shop who have the correct scan tool for your vehicle. The scan will display what part is defective. The flashing light shows the need for attention and where the attention is required. As an example; if the engine check light is flashing that unit will be the centre of the investigation. When the overdrive light flashes, the problem is with the gearbox. Regards Johngee10
Mar 11, 2011 | 1994 Ford Crown Victoria
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
! keeps flashing
Check on the error message that appears on both your monitor and printer....most of the time you run out of paper, a paper jam, or a low ink cartridge....whatever message that is it needs your attention!....cheers
Apr 11, 2009 | HP Photosmart D5160 InkJet Printer
Attention Light Flashing
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Oct 08, 2008 | HP LaserJet 1020 Printer
Attention light flashing- says replace black cartridge
Try reset the printer. Turn off powerswitch, press gobutton, turn on powerswitch while pressing gobutton. hold approx 15sec and release the button. The printer will reboot. Clean the cartridge contacts and HV pins in printer.
Sep 30, 2008 | HP LaserJet 2420 Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
18 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
