Question about Whirlpool Washing Machines
Day@letton-hall.commodelV8Ta2KuT(3B) does not introduce hot water into the machine although temp.select is hot or warm water
    President:
  • 2,468 Answers
Your hot/cold water valve solenoid on the rear where the water enters isn't opening,you need to replace this valve where the water hoses enter the rear area hose inlet connections
Posted on Jul 29, 2010
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
No Full Hot Water wash
the hot selection only tells the machine to turn on the house hot water to the machine
if you have it on warm , then both taps will be working
if you want a really hot water wash , there will be an element in the tub to bring it to temp
naturally an energy saver will not waste money heating hot water
Sep 15, 2017 | Washing Machines
2004 washing machine temp
From the unit itself you'll need to check your owner's manual and select warm or hot water temps. You also can turn the water temp up from the hot water heater in your home.
Jul 17, 2012 | Frigidaire FWS833A Top Load Washer
GW712 - cold wash selected but water runs warm. If hot water supply turned off, machine stops?
The cold water temp has been adjusted to a warmer temp,
Move the led back to the first led light with advance button.
Jul 01, 2012 | Fisher and Paykel GWL11 Top Load Washer
No water is coming through when HOT water temp is selected. only on COLD. and COLD comes through when WARM is selected.
Sorry to read about your problem, I hope this helps you out.
sounds like your temp selector control is defective..
try this
on warm or hot, turn off the cold water valve at the wall.. you should get hot water, if you dont..you may have a defective hot-water inlet valve
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Washing Machines
Machine squeals when filling
Hi just read your posting.Now what temp of water are you selecting for the wash cycle,is it warm, cold, or hot.Try this,Select hot fill then select cold fill and please reply on whether the squeal stops on either hot or cold fill.Looking forward to your reply.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
WPXH214A Water Temp: Any selection that has Warm
The cold side of the water valve is either clogged or not opening. Take the cold water hose off of the machine and see if the screen is clogged. If clean you may need to replace the water valve.
Feb 25, 2010 | GE WPXH214A Front Load Washer
Machine is putting out warm/hot water when cold setting is selected. replaced water intake valve and problem persists
depending on the model this could be right
some inject hot water to acheive a cold water rinse
of a min of 60 degrees
if there is a problem its with your temp control
Oct 02, 2009 | Washing Machines
Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Dec 22, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Washing Machines Logo
21 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
