Question about Toshiba TDP-T91U Multimedia Projector
How do you open this projector to repair a capacitor on the power supply? It won't power up
  • 22 Answers
Philips head screw driver...need to remove all the screws that hold the case together...
Art
Posted on Aug 02, 2010
Lc4441 projector repair
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | Philips Lamp for Philips CBRIGHT LC4441 -...
We have an older Runco projector, last week the porwe light turned off and it no longer pwers up. I tested the outlet and tested plugging the projector into a different outlet with no luck. Is there...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video.
Jun 19, 2014 | Runco Office Equipment & Supplies
Hitachi 1350 projector dead, no power. cleaned everywhere, changed the bulb, nothing I do gets power into it.
I assume the projectors are of similar age and have similar useage history? Not certain why they would fail together, but the most probable cause is faulty switch mode power supplies. The electrolytic capacitors in these supplies a relatively short working life, especially when installed in high temperature environments - like a video projector. new caps in the supplies may be all that's required to solve the issue. If you have other similar projectors, they may well be approaching the same problem.
Any reasonably competent TV repair tech should be able to check the supplies for you, and repair them if found faulty :o)
Apr 05, 2014 | Hitachi PJTX100 Multimedia Projector
Runco CL710 projector. Had power outage and projector won't turn on. Project was plugged into surge protector. Surge protector is working, green light is on. Checked all electrical breakers, they are...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
Aug 25, 2013 | Runco CL-410 Multimedia Projector
Projector shut off
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. Pretty easy fix.
Jan 02, 2012 | Runco CL-410 Multimedia Projector
I have no power to my runco cl-710 projector.... no lights will come on regardless of the power cord I use. I have made sure the lamp cover is on securely and correct. any ideas?
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. This is an easy repair.
Jul 18, 2011 | Runco Office Equipment & Supplies
Picture grew dim and then finally went out.
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on howto replace capacitors.
Jun 13, 2011 | Runco Reflection VX-1c Multimedia...
HP VP6210 won´t turn on at all
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Toshiba TDP-T91U Multimedia Projector Logo
61 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
