How the hell do i re enable the mouse pad on a HP 4520 laptop ? it has locked itself and i cant seem to find the right button-please help
    Sergeant:
  • 313 Answers
The first place i would look is control panel and click on mouse control. see what is in there and what settings your computer has got there. see if there is any thing that is disabled. Make a note of what changes you have made in case you need to change it back.
Posted on Jul 29, 2010
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
Nov 29, 2013 | HP ProBook 4510s FM849UT Notebook
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
How to unlock the mouse of hp pro book 4520
Thank you for using fixya.
Enable for you to unlock the mouse pad of your HP laptop, press FN + F7. However, there are some instances when that key won't work for some apparent reasons. But, don't worry because there are some other ways on how to make it work. I have provided a link below. This is a link to a tutorial on how to unlock your mouse/touchpad. Click on the link below:
http://www.fixya.com/support/r8113144-enable_touchpad_in_laptop
Thank you for trusting fixya.
Carloadrian
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 06, 2011 | Computers & Internet
HP Mini Touch Pad Right Mouse button auto click...
it may be a setting on the touchpad that you can set in control panel
Apr 24, 2010 | HP Mini 1000 Netbook
I have an e machine E627 and my mous pad seems to be locked the mouse won't move what should I do
Hi there please follow these key. Press FN+ F7. these key use for mouse pad enable / disable purpose. F7 key should marked a mouse pad symbol. Otherwise please watch those symbol in below the image & press that key with FN.
9c654de.jpg Thanks & waiting for your feedback.
Feb 09, 2010 | Acer eMachines 520-2890 Notebook
Toshiba satelite M200 touch pad not work
saket,
try to find out if there is any button for you touchpad on the keyboard, if you found then press this and try.
If you did not find then try the following:
  • Goto Start -> Control Panel
  • Double click on mouse icon
  • Then goto Device setting, there you can find an option/button to make your touch-pad enabled/disabled. Make it enable and try.
Thanks
Iqbal
Apr 28, 2008 | Computers & Internet
Touchpad issues
What Toshiba do you have? Without knowing that it is would be hard to help you.
Is this a new laptop?
One suggestion I can say is: Check on near at the mouse pad area to see if there is any button that enables or disables features of the mouse pad.
Jan 15, 2008 | HP Pavilion dv6000z Notebook
Mouse locking/turning off laptop
On your laptops power management settings, you will probably find an advanced tab. In there you should be able to assign the power button to 'Shutdown', as it is probably 'Hibernate' enabled. The mouse problem is probably your laptops touch pad driver, update drivers from Hewlett Packard site if there are any.
Oct 24, 2006 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
140 people viewed this question
Alun Cox
David Payne
David Payne
