My 50pc55 lg tv has stopped working.There is no picture.Fan can be heard all connections are good and can be turned on via handset.But still no picture.Any ideas?
5 Suggested Answers
  • 92 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Posted on Oct 31, 2007
  • 15 Answers
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
  • 188 Answers
SOURCE: LG 42PC3D Plasma: No picture, good sound
One of the SUS panels will be defect.On these panels you will find several fuses,the panel with the broken fuse must be replaced.
Sus panels are the panels with the big cooling blocks.
Posted on Jul 20, 2009
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Lg 50pc55 plasma- has sound but no display??
Quite possible-----replace all bad ones and also if possible the voltages coming out of that board need to be tested---to be honest other than the caps it sounds like a main board issue. The set may have been run too long with the bad caps.
Dec 08, 2012 | Televison & Video
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
Apr 13, 2009 | LG KU990 Viewty
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Tv no picture
Have you checked the input on the tv yet? maybe someone changed the tv input using the video source key on the remote. Also check all the connections from the tv to your equipment like the cable from the cable box or wall. If the connections are good call a repair man. Its just something that happens, maybe a power surge. Call firedog
Nov 13, 2008 | LG 42LC2D 42 in. LCD HDTV
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
