Question about Kodak ESP 5 Printer
Severs paper jam
Sever paper jam unable to get paper out of printer
    Sergeant:
  • 313 Answers
Try turning the printer OFF wait 10 seconds then try carefully pulling the paper out. Then swith printer ON and let it sort itself out befor reloading with paper. Some times the printer gets greedy and takes in more then one sheet.
Posted on Jul 29, 2010
I have a 4500 office jet and the paper is severly jammed. can the printer be taken apart to fix this problem
Yes; there is a great (official HP !) video tutorial on how to take it apart properly here:
Jul 17, 2014 | HP Office Jet 4500 G510n
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Paper Jam/Cartridge can't move
    Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
    Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
    Roller drags several sheets of paper and results in a paper jam
    Open your printer and release jam paper then solve problem.
    Apr 09, 2009 | Lexmark E322 Laser Printer
    What is 'print unable 51' never had a paper jam!
    Do the following:
    Print Unable
    XX
    The machine has a mechanical
    problem.
    —OR—
    A foreign objects such as a clip or
    ripped paper is in the machine.
    Open the scanner cover and remove any foreign
    objects inside the machine. ( You might try cleaning the scanner glass.)
    If the error message continues, disconnect the machine from
    the power for several minutes and then reconnect it.
    Try this and let me know what happens. Binary Bob
    Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
    Unable to open to remove paper jam
    Step1
    Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
    Step
    Turn off the printer.
    Step
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
    Step
    Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    Step
    5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    Step
    6
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    Step
    7
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
    Step
    8
    Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    Step
    9
    If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    Sep 23, 2008 | Canon PC1061 Copier
    Paper jam
    Step1
    Step
    Step
    Step
    Step
    5
    Step
    6
    Step
    7
    Step
    8
    Step
    9
    Sep 06, 2008 | Brother MFC-5440CN All-In-One InkJet...
    Unable to print
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
      Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
    1. If the error continues to appear, the machine may have a mechanical problem.
      If the error message continues to appear, the machine will need to be reset.
    See page 123 of the manual for more. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
    Sep 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
    Kodak ESP 5 Printer Logo
    212 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
