Question about Black & Decker 50 Watt Electromate with Radio and Lantern #PS50LRB
Is this the same lantern as the Power on Board TrailTracker Sport Lantern Weather Radio? I am looking for a replacement batery pack for mine and can't find one.
Where can I get a replacement battery for the trail tracker, emergency radio lantern, yellow?
Trail Tracker Sport Lantern/Weather Radio doesn't charge using the hand crank dynamo for my Power on Board Trail Tracker lantern/radio, You most likely need a new battery, you can purchase one from Black...
More information please open this link:-- Best Manuals
Jun 17, 2016 | Cars & Trucks
Tip
SAFETY 1. HANDLE WITH CARE AND AVOID CONTACT WITH CORROSIVE LIQUIDS. 2. AVOID...
SAFETY
2. AVOID LEAVING YOUR UNIT IN DIRECT SUNLIGHT OR IN HOT, HUMID OR DUSTY PL.ACFS
3. KEEP YOUR UNIT AWAY FROM HEATING APPLIANCES AND SOURCES OF ELECTRICAL NOISE SUCH AS FLUORESCENT LAMPS OR MOTORS.
4. ALWAYS TURN YOUR RADIO OR LANTERN OFF WHEN NOT IN USE AND REMOVE BATTERIES IF YOUR UNIT IS NOT GOING TO BE USED FOR LONG PERIOD.
5. OLD BATTERIES CAN LEAK AND CAUSE CORROSION DAMAGING YOUR UNIT.
6. LAMP BULBS OR LANTERN SHOULD ONLY BE REPLACED BY QUALIFIED TECHNICIAN.
NOTE: OUTPUT POWER: FM-550 mw,
AM-405mw
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Tip
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
Where can I get a replacement battery for the trail tracker Sport lantern?
You can get a replacement at your local Interstate battery store. I purchased one for $30
Jul 15, 2010 | Black & Decker 50 Watt Electromate with...
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Is the Weather Channel TV/Lantern/VEC130B digital?
I have the same TV as in the picture and it is analog(didn't check model #). I know of no way to use a converter box on it short of hacking it apart. Although it can still pick up any low power analog channels that maybe in your area. I just bought a nice hand cranked paperweight just a few years ago. lol
Nov 11, 2008 | Weather Channel COMPACT TV/LANTERN/ EA...
Black & Decker 50 Watt Electromate with Radio and Lantern #PS50LRB Logo
604 people viewed this question
Top Black & Decker Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black & Decker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
