When printing 8161 labels, they do not align on the labels
    President:
  • 670 Answers
I don't know what software you are using to print the labels, but if you are using a word processor like Word, make sure that page settings are correct and match the labels that you are using. Check also the font that you are using to see if a smaller one would fit better. I might be able to help you better if you describe the software that you are using, what you are printing, and how are the labels being mis aligned. Thanks!
Posted on Jul 29, 2010
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
My printer always start printing short so that the lables end up on two pieces instead of one
We must establish whether the problem is a moving label or just that the labels are not aligned properly. Is hte printing split across the two labels consistant regardless of hte number of labels printed? If so, then the lables are not aligned properly. The user manual has the procedure for aligning these. This is part of the setup procedure.
If hte first line of the labels changes position on subsequent printings, then either the label size is not defined properly or the format being used is not correct. I don't have the manual handy at the moment so I can't give you the particulars, but if you could update this and tell me which of the 2 conditions you are experiencing, I will look up the specifics in the morning.
Thanks,
Dan
Dec 09, 2010 | Zebra Z4M Printer
TEC B-572 printer, labels off center.
Check the alignement of the media guide. and the alignement of the print head. + X adjust parameter
May 15, 2010 | Toshiba TEC B-572 Printer
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
Label alignment
see if you can download from here: http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
Z4MPlus Users guide is the fourth one down.
Mar 12, 2010 | Zebra Z4Mplus Label Printer
Can t print labels they are not align zebra 2844
Press and hold the feed switch and when you see 4 flashes, release the button. The printer will calibrate and you should be able to see the labels align
Oct 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Open Questions:
44 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
