Question about Miele K2214S Compact Refrigerator
Freezer not working evryting meled
Opened th door of the feezer and found everything melted The fridge is working an the freezer makes its beeping noise hen th door is left open
4 Suggested Answers
  • 171 Answers
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
heatman101
  • 43501 Answers
SOURCE: Fridge freezer kfn 9755 ide
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
caroldon
  • 17130 Answers
SOURCE: i need a door handle
Please checck and see if you find help with the following link:
http://www.espares.co.uk/parts/fridges-and-freezers/door-handles/p/1544
Posted on Jun 21, 2011
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Freezer works as usual. refrigerator food area not working.
if you have another fridge you can put the food in it and leave this fridge unplugged and just let it melt out overnight or melt out the air vents with a hair dryer.empty the freezer,remove the back inside wall and melt everything out and clean the ice off of the packages,you should have no problems with the fridge after that.common problem with kids.
May 31, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Ice forms around fan and makes a loud humming noise
It's probablly caused by air leakage through the ice room fan electrical connection inside the freezer. Behind the back wall inside the freezer, the icd fan is the fan that blows air up to the in-door icemaker. The plug on that, into a molded plug on the back of the feezer compartment, is a red plastic part with three wires in it. Try filling in around the wires and the red plastic with a bit of silicone. (if you replace the ice room fan, the new plug comes with a rubber filler which seals this spot). (PS. Next time, avoid Sears)
Mar 31, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
FRIDGE/FREEZER ON THE BLITZ?
Try removing everything out of your fridge, switch it off and open all doors for 12 hrs. Then close doors and switch it on for another 24 hrs before putting in you stuff. most likely the evaporator is iced up, you need to defrost if fully.
May 04, 2009 | Refrigerators
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Fridge/ Freezer not cold
My fridge started making a weird noise not too long ago. Now the fridge isn't cold and everything in the freezer is melting. The read out still says that everything is the right temp, but the melted ice tells me otherwise. Recently my daughter found out how to operate the buttons and has been pushing them a lot, but we change them quickly.
I would have the refrigerator / freezer checked out by a serv tech mainly because if it is a compressor, this would not be something that can be done by as customer, but it could be something internal like a fan or a fan motor that blows the cold air or a bad thermostat or sending unit – the weird noise is something internal that really should be check out by a serv tech before you lose everything as far as food, etc. – the refrigerator is a sealed unit and is hard for a customer to service unless they have serviced the unit before.
Apr 08, 2008 | Samsung RB2155SH Bottom Freezer...
Miele K2214S Compact Refrigerator Logo
19 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
