Question about Nady Systems Nady ATM-75 Headset Mic w/ Mini-XLR Headset
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not work. I thought that the mini XLR plugs would have a standard neutral, ground and hot no matter who's microphone you are using. Can anyone explain? Is there a different type of adapter I can use or are they just incompatible? Microphone is a Samson SE50 Wireless System is a GTDAudio G-788L-200 channel UHF PLL wireless microphone system
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Posted on Jul 22, 2011
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Hi There, My samson airline wireless 77 mic has stopped working. Can somebody please advise of the best number to reach a samson tech support or service centre on? Thankyou!
Shipping Address:
Samson Technologies Corp.
45 Gilpin Avenue, Suite 100
Hauppauge, NY 11788
Phone Numbers:
Phone: 631-784-2200
Fax: 631-784-2201
Primary E-mail Contacts:
Information - info@samsontech.com
Sales - sales@samsontech.com
Support - support@samsontech.com
Literature Requests - literature@samsontech.com
Direct Brand E-mail Support:
Samson Wireless - wireless@samsontech.com
Samson Audio - audio@samsontech.com
Hartke - hartke@samsontech.com
Zoom - zoom@samsontech.com
International Contacts:
For Samson Audio, Samson Wireless and Hartke please use our International Distributors Page to find the contact information of the Distributor for your country.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 12, 2011 | Samson AH1 Professional Headset
I had to buy a new power adapter for my stage 5h wireless system. When I plug it in, the power LED flashes. Is that what it is suppose to do? I can't get it to work at with the new adapter.
No it shouldn't flash. Did you buy the manufacturers own power adapter or did you just buy a universal one?
If you bought a universal it could be that you have the wrong polarity (+ve and -ve the wrong way round)
Feb 22, 2011 | Samson STAGE 5 Consumer Microphone
Microphone not working
hello there, Many steps to do
1. For your AirLine system to work correctly, both the receiver and transmitter must be set to the same channel. and check to make sure that the supplied receiver and transmitter are set to the same channel.
2. Physically place the receiver where it will be used (the general rule of thumb is to maintain "line of sight" between the receiver and transmitter
so that the person using or wearing the transmitter can see the receiver). The CR77 can be rack-mounted if desired (taking a half-rack
space), using an optional Samson adapter kit. The UM1 can be mounted to a video camera using the supplied velcro.
3. Extend the receiver antenna(s) and place it (them) in a vertical position. Make sure the Power on-off switch in your AH1 transmitter is set
to "Off."
4. Gently pry off the battery cover off the AH1 transmitter and slide it upwards and off to open the battery compartment. Please use care
when opening this cover as undue force will destroy the hinge.
5. Place a fresh AAA alkaline battery in the transmitter battery compartment, taking care to observe the polarity markings. Then replace the
battery cover and gently press down on it until it clicks. Leave the AH1 off for the moment.
6. Make the physical cable connection between the receiver output jack and a mic level audio input of your amplifier or mixer. The balanced
XLR jack is preferable, since it will deliver an electromagnetically cleaner signal. If required, both the balanced and unbalanced outputs
can be used simultaneously. If your system contains a CR77 or UM1 receiver, be sure to set its Audio Output Level switch correctly (see
pages 7 and 9 for details). Leave your amplifier (and/or mixer) off at this time.
7. Turn the Volume, Level or AF Level knob on the receiver completely counterclockwise. Connect the supplied AC adapter to the CR77
receiver and plug it in (the UM1 receiver can also operate off battery power or a 12 volt power supply from a connected video camera), then
plug the adapter into any standard AC outlet. Slide the Power switch in the direction of the arrow to turn on the receiver. If your system
contains a CR77 receiver, its "Power" LED will light steadily red. (Note: The UM1 receiver has no "Power" LED indicator.)
8. Turn on the power to your AH1 transmitter (using its Power on-off switch); the "Power/Battery" LED will flash if the battery is sufficiently
strong (if it lights steadily, the battery has less than 2 hours of power remaining and should be replaced). If your system contains either a
CR77 or UM1 receiver, one of the "A/B Receiver" LEDs will light, showing you whether the (left) "A" or (right) "B" receiver is currently being
used. The CR77 / UM1 meter will also indicate the strength of the incoming RF signal.
9. Now it's time to set the audio levels. Turn on your connected amplifier and/or mixer but keep its volume all the way down. Make sure
that the AH1 transmitter is unmuted (its Mute switch should be positioned away from the arrrow). Then set the Volume, Level or AF Level
knob on the receiver fully clockwise; this is unity gain.
10. Speak or sing into your headset mic (or play the instrument to which the horn mic is attached) at a normal performance level while
slowly raising the volume of your amplifier and/or mixer until the desired level is reached. The UM1 receiver allows you to monitor the
transmission signal using standard Walkman-type 30 ohm headphones connected to its headphone jack.
11. If you hear distortion at the desired volume level, first check to see whether the "Peak" LED on the receiver is lit . If it is not lit, make sure
that the gain structure of your audio system is correctly set (consult the owners manual of your mixer and/or amplifier for details). If the
"Peak" LED is lit, simply move the microphone further from your mouth.
12. Conversely, if you hear a weak, noisy signal at the desired volume level, again make sure that the gain structure of your audio system
is correctly set (consult the owners manual of your mixer and/or amplifier for details) and that the Volume, Level or AF Level control of the
receiver is fully clockwise. If it is and the signal coming from the receiver is still weak and/or noisy, simply position the microphone closer to
your mouth.
13. Temporarily turn down the level of your mixer/amplifier system and turn off the power to your transmitter, leaving the receiver on. Then
restore the previously set level of your mixer/amplifier. With the transmitter off, the receiver output should be totally silent-if it is, skip
ahead to the next step. If it isn't (that is, if you hear some noise), you may need to adjust the receiver Squelch control. When the Squelch
control is at its minimum setting, the AirLine system always provides maximum range without dropout; however, depending upon the particular
environment your system is used in, you may need to reduce that range somewhat in order to eliminate band noise when the AH1transmitter is turned off. To do so, use the provided screwdriver to rotate the Squelch control completely counterclockwise (to the "Min"
position), then slowly turn it clockwise until the noise disappears. If no noise is present at any position, leave it at its fully counterclockwise
"Min" position (so as to have the greatest overall range available).
Thank you and if you any more help let me know and don't forget to Rate
Jan 26, 2011 | Samson Airline 77 Aerobics Wireless...
Hi We use a Samson UT-5 at my church. Recently it seems like there is static/buzzing noise whenever our priest touches the connector. Is there a connector problem or should we take it to a repair store...
That sounds like a floating ground problem.
The UT-5 is a beltpack transmitter, right? What microphone do you have plugged in to it? We use a Countryman headset with a Sony beltpack, and there are components inside the connector for our setup.
Try unplugging the microphone and see if you can make the beltpack buzz without a microphone. If so, then it's in the beltpack. If not, it might be the mic cable.
Apr 03, 2010 | Countryman E6i EARSET f/SAMSON UT5/TX3...
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Will the Iogear GBMA211 Wireless Audio Transmitter (GBMA211) work with ANY bluetooth headset I have a Motorola S9???
No, it will not work with other headset like Motorola S9. The GBMA211 Audio transmitter is tested to work with the GBMH211 IOGEAR Bluetooth headset.
The GBMA211 was tried with the other Bluetooth headset but no success.
Jan 14, 2009 | IOGear GBMA201 (GMA201) Bluetooth Wireless...
Nady Systems Nady ATM-75 Headset Mic w/ Mini-XLR Headset Logo
459 people viewed this question
Top Nady Systems Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Nady Systems Radio Communication Expert? Answer questions, earn points and help others
