Question about Microsoft Xbox 360 Console
How can you get rid of a scratch on a disc for a xbox360
I played for like 5 hours and now my disc has a ring on it because of the xbox can someone help me out
    Scholar:
  • 203 Answers
Okay, that ring is there because at some point while the system was on, your xbox was bumped or knocked over or something. You can TRY to resurface the disc, i have heard from some people that they were able to do so successfully. If this doesn't work, then there's no way to fix it, your going to have to get a new copy of your game. Sorry :(
Posted on Jul 29, 2010
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Xbox360 seems to be scratching discs
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 laser burn disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
You can send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
If this is happening consistently without any knocks or movement of the console, I would contact Microsoft for advice on your games console.
Jan 11, 2010 | Microsoft Xbox Console
Big rings on the disc
A common problem that XBOX owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. They can be fixed!!!
For further help on XBOX & XBOX 360 disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
Hope this Helps!!!
Mar 27, 2009 | Microsoft Xbox 360 Elite Console
Ring on game
There is a known problem with xbox units scratching discs and Microsoft have a Disc Replacement Policy - check out
http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx
Mar 20, 2009 | Microsoft Xbox 360 Console
Xbox360 defective and ruined games.brand new console and games.
Hello.
Xbox DVD-Drive's often scratch circles into your discs and some even got malfunctioning lasers that will burn rings into games.
To prevent the circular scratched from happening avoid moving your console at any time while it is running however it often also occurs just in regular use especially for older consoles with Hitachi or Samsung drives.
As far as I know Microsoft replaces discs that were clearly damaged by a console free of charge, at least here in Europe they do.
Try calling Xbox Customer Support and ask for a replacement it is worth a try for sure even if they shouldnt replace it they will at least give you a 1-month subscription for Xbox LIVE in exchange.
If you can get the console replaced as well depends on the support person you are talking to but usually they charge you for that if you want to fix the drive yourself, open up a PC drive and take the foam pads outs and install them in the 360 drive this will prevent the discs from getting scratched they just didnt use these pads in the Xbox for some reason which led to these problems...
I hope this helps and Good luck!
Kind regards,
Wilhelm@Xboxexperts.com
Dec 26, 2008 | Microsoft Xbox 360 Console
Disc ring
While disc scratching is known to occur if you move your XBox360 console from vertical to horizontal position while the disc is spinning or by bumping the console while the disc is spinning, there have also been reports that discs have become scratched when the console has not been moved at all. The official line from Microsoft is: "If you are experiencing scratched discs without moving your console you should contact 1-800-4MYXBOX for warranty support from Microsoft." Unfortunately, Microsoft will not replace your scratched discs for free. Instead, they offer a scratched disc replacement program with a charge of $20 per disc. To take advantage of this program go to the XBox website and search for "XBox Disc Replacement Program".
Apr 15, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 scrathes my disks while inside the xbox
It sounds to me you have your 360 standing on it's side. I placed mine on it's side ONCE and because of it have a pretty scratched copy of Oblivion. Lay it horizontal, and that should rectify your issue. Let me know if this helps.
Aug 18, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
