I have owned a Sony rear projection TV for a little over two years. Model KP-51HW40. I have two problems. The first problem has been going on for about one year. Most of the time when, it is first turned on, the screen will flash a few times and then it goes into a "standby" mode. The red "Standby/timer" light on the front of the TV starts blinking. I have to press the power button to get the picture back on. This will normally happen for two or three times before it will stay on. Sometimes if the TV is turned off for a short time and then turned back on, I have to go through that cycle 10 - 15 times before it works. I called Sony and was told to unplug it to reset everything - but that doesn't work. I have looked thru my manuel and find nothing about putting the TV on "Standby" The second problem occured the other night. I now get a double image and each one is a different color - red and green. I assume that the blue bulb has burned out. The picture on the right side of the screen( about 25% of the picture) seems to be ok with all colors and in focus. If the blue one is out, is this something that I can replace or does it require an expert? Should I replace all bulbs or just the one that is out? What is the expected life of these bulbs?
  • 4,234 Answers
Problem # 2 is a convergence issue. If you can solder, you can repair this yourself. As far as problem #1 goes, count the blinks. The set goes into standby as protection from further damage when a problem is detected. The blink count is an internal diagnostic that indicates the circuit in which the problem was detected. Report back here with the blink count if you can.
I'll look up the convergence IC numbers in the mean time.
Dan
Posted on Apr 24, 2008
My Sony KP-51HW40 is underscan!
If you have already changed the aspect ratio on your TV, then change it on your cable or Sat box. Your TV appears to be operating normal.
Jun 17, 2012 | Sony KP-51HW40 51" Rear Projection...
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Aug 21, 2009 | Sony Televison & Video
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Lines on my screen
Try this link it has many great reviews. Very informative for the DIY. The description of your problem was very vague. If this helps great.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
271 people viewed this question
Top Televison & Video Experts
Electro Med Services...
