Question about Samsung LN-S2641D 26 in. LCD HDTV
Samsung LN-S26441D Dear Sir, I was wondering if you could help me with a problem with a humming sound that comes out of the speakers. Both the surround sound theater system and even the built-in speakers of the TV have this maddening sound comming out of it. I have tried everything, new cables, disconnecting the TV for a day, tried all the manual troubleshooting suggestions, all to no avail. The humming is very distracting. There is no clear sound comming from the television no matter what I do. Thank you very much for your time. Any help would be very much appreciated. With kindest regards, Bruce
    Genius:
  • 1,074 Answers
My friend check the filter cap in the power supply it can be a 470 mfd or little bigger this cap is leaking replace it.if that does not work check all the cap in the power supply and replace them ,the problem is that one or two of them are not smoothing the ripples causing the humming sound.contact me if that does not correct your problem.
yours snakehead
Posted on Apr 26, 2008
Ln-t1954h firmware upgrade
sir please help me my samsung lcd Modele Ln-t1954h change NTSC to PAL. please send my Email addres digital636@gmail.com
Jul 07, 2012 | Samsung LN-T1954H 19 in. LCD HDTV
My flat panel samsung LN-T4661F 46in. has developed a static sound coming from the left speaker and is also apparent when the sound is piped thru a stereo system
unfortunately there is no way to fix this short of taking the unit apart and checking for loose connections, which may cause more problems than it solves, either take it to a tv repairman or hope it doesnt get any worse :s
Mar 05, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
I have a Samsung LN-T1953H TV and the sound suddenly stopped working. We were watching a DVD and suddenly no sound. The TV picture still works fine but there is no sound. on any of the connections or...
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Mar 18, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
Samsung lns4041d sound doesn't work
1) Check out the on screen audio setup menu to see if the spekers are set to OFF.
2) Hook up a powered PC speakers to the Audio line output RCA jacks to see if you get the sound OK to isolate the problem to be the power amp or audio processor problems.
Nov 03, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
I'm experiencing an audio distortion in my speakers when the sound is above 32. it sounds like a low roaring. how can i remedy this situation?
Check speakers or speakers ok just need replaced main board
Manufacturer Samsung Part Number BN94-00963E BOARD, MAIN ASSY
Sep 23, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Headphone jack fault on 32" samsung TV
I don't know about replacing a jack but BN94-01208C fits LNT1953HX is the main pcb that has all of the av inputs on it and it is a snap to change.
Aug 03, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
Samsung LN-T1953h audio not working correctly
It sounds like the headphone jack may be going bad. I do not know how to replace it, but if you can find BN94-01208C fits LNT1953HX all you have to do is swap out the main pcb with the new and you have a working tv agin.
Jul 20, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
New Samsung Tv High pitched hum
Don't know if people are still having this issue or not but figured I'd post what i went through to help anyone that has. My LN-T3253H tv as out of warranty when I finally got around to calling Samsung. They flat out lied about the commonality of this problem and I convinced them to at least pay for any parts. Problem is the labor of a technician would be around $150. So, I bought the new power supply from Partstore.com for around $70. Just go to partstore.com and enter your model number and look for the power supply on the page. It took 3 days to get the part. It was very easy to replace. All you have to do take off the back cover of the tv (think there were around 12 screws all around the outside and one where the A/V connections are and pull off. Unhook the plugs going to the power supply and the four screws holding the board and then replace with the new board. So far, this fixed the issue. Keep your old board in case it starts happening again. You can probably have the old board repaired to fix the original problem since so many TV repair shops are aware of the issue. I am trying to find out from someone which specific capacitor or other piece is causing the issue and plan on fixing it myself. If and when I do, I will also post that.
Make sure you give Samsung a ton of grief when you speak to them and see if they lie to you also. I had just bought two of the new Samsung LED TV's for my media room. They work great but I returned both because of Samsung's refusal to fix my LN-T3253H and I will never, ever buy Samsung products again.
Mar 24, 2008 | Samsung LN-T3253H 32 in. LCD Television
Samsung LN-S2641D 26 in. LCD HDTV Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
