Question about Cell Phones
On my Motorola T305 MOTOSTART the indicator light doesn't come on either when the power button is pressed after the charger is plugged into the charging port or when it(the Motorola charger) is removed. ie the handsfree machine (T305)won't start..
SOURCE: Motorola RAZR won't charge
don't buy a razr v3 because they obviously suck
Posted on Jan 22, 2008
Bajanguru
  • 7752 Answers
SOURCE: cell phone won't charge/or hold a charge
you are not to keep a phone charging that long...only charge a mobile when the battery is completely dead that is the only way that you will have a good battery for a long time.
what you should do is try a new battery with the work and see if that helps other then that you will need to have the phone usb port service or checked.
Posted on Jun 23, 2008
  • 61 Answers
SOURCE: Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Posted on Feb 05, 2009
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm :)
Posted on Feb 27, 2009
timthorne911
  • 464 Answers
SOURCE: Pass code for Motorola T305
0000
Posted on Mar 18, 2009
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I am trying to connect my T305 portable bluetooth car speaker phone to work with my iPhone 3G, but I keep getting Motorola T305 not paired What should I do?
Hold the power button in on the speaker system until the indicator light turns purple. Have your Iphone scan for bluetooth devices and select the T305. The first time it connects it will ask for a security key which should be 0000. If that doesn't work try 1234 as well.
At that point it should pair successfully and you should be good to go.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility Bluetooth Hands-Free...
How to configure or pair my motorola T305 car bluetooth with my mobile nokia E63
First step:From your nokia e63,scroll to bluetooth goto paired device and click on add device after that,then pick up your bluetooth and press down the power button make sure you did not remove your hand from the button until it displays on your phone.
Second step:After your phone has found the device,click on the device from your phone and you will be ask to type a password which the password is 0000.enjoy
Jan 30, 2011 | Motorola Mobility T305 Bluetooth Speaker...
My lg phone says no device found
Ok. Take T305 in your hand. Hold the call button until you see purple light steadily lit. Then release the button, but when you see the blue light steadily lit, you're ready! Now try finding the device named: Motorola T305. The password is: 0000. Headset will check the password, pair you,and that's it! Good luck with using!
Nov 23, 2010 | Motorola Mobility Bluetooth Hands-Free...
Neither 0000 or 1234 work as Motorola t305 passwords
I wasn't able to locate any documentation on a factory reset, but if it is like all of their headsets, press and hold both volume buttons and the call button at the same time - hold it for 10 seconds and it should reset - IF it works the same. If it does, the default passcode is 0000
Mar 07, 2010 | Motorola Mobility Bluetooth Hands-Free...
How do i set my my motorola h350 into discoverable mode
Plug the Motorola charger into the end of
the headset.
The blue indicator light turns on when the
battery is charging. It may take up to 1
minute for the light to turn on. When the
headset's battery is fully charged (about 2
hours), the blue indicator light turns off.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
How do I pair my t305? how do you put it in the mode to pair?
Hi waddellwilli,
According to the Motorola website :-
Power on headset by sliding the Call button towards the microphone to initiate easy pairing.
After a few moments, the indicator light will be steadily lit in blue to indicate headset is in pairing mode.
For information on how to set up a specific mobile phone and a link to the user manual visit :-
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=06e1dd9fc0e2b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=159e463f04a0f010VgnVCM1000008206b00aRCRD
Copy and paste this link into your web browser.
Hope this helps.
Mark.
Apr 12, 2009 | Motorola Mobility T305 Bluetooth Speaker...
Bluetooth/phone connection problems
If you turn on the headset and then press and hold the button until it starts flashing rapidly(or if it usually does this stays on) whilst doing this set your phone to PAIR BLUETOOTH DEVICES in the settings menu.This should pair your devices
Apr 07, 2009 | Motorola Mobility Bluetooth Hands-Free...
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
