Question about Sony Ericsson Walkman W810i Cellular Phone
Software and coverage problems
I have coverage prolems.i have also the software problems.because of software problem my mobile charging works only for 8 to 9 hrs only.when mobile is full charged any call comes or do outgoing then after talking 10minute battery indicates on red and after disconnect the call after 5 minutes battery comes in full charging position. so tell me what to do and which latest software i can download and from which site i can get it.
thankyou
  • 624 Answers
Hello and Welcome to FixYa!
Hmm, it may be the software problem but I am also smelling some hardware malfunctioning here. Even though why shouldn't we try what we can. Yes sure you can download and install the latest updated firmware from the link I've provided below, BUT for this you should have the USB Data Cable and an active internet connection. If you have them just follow the link, all required information / guide and software are available there. Download the utility, install it and run it. The wizard will guide you on how and when to connect the phone.
Note: Also backup the data/contacts before updating as after that the phone will be in out of the box condition.
If you are having any trouble/questions, do ask me. We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: W810i Firmware Upgrade
Posted on Jul 29, 2010
Flashing red
Try uninstalling the unit, and then install it again. After you have reinstalled the software, try to reset the headset:
Press and hold the Power/Send/End button and connect the charger at the same time. The headset is turned off and reset. Afterwards, try re-charging the unit (if necessary) to see if that resolves the issue.
If this doesn't fix it, I would recommend pursuing replacement options. Bear in mind, if warranty coverage has expired, you would be responsible for the cost of another item.
Jul 03, 2013 | Rocketfish Rf-qx4 Mobile Bluetooth Heads
Sir, i have been using sonyericssion k550i mobile for last 2years.now it has got problem and shows no network coverage and when i used the same sim in another mobile its working.what should i do now and...
You can do it yourself, and save all the money IF and only IF you have the USB Data Cable of your phone, if you have it then proceed, if you haven't got one then you need to contact some service center and tell them to flash the software/firmware of your phone. They will not charge you much for that.
Now, if you have the cables, download the update utility from here, after downloading, install and run the application. The wizard will automatically check for software updates and will install the firmware to your phone. Do note that your phone should be 50% charged and your PC should have an active internet connection.
Its easy and worth a try before going anywhere, If you are having issues/questions, do ask me. I'm here to help.
Regards, Nooh
Aug 12, 2010 | Sony Ericsson K550i Cellular Phone
System erro
its software prolem getg flashed ur mobile fone from a certified mobile fone repairer/..
Nov 05, 2009 | Nokia N95 Cellular Phone
Just got No Network Coverage on my Sony ericsson C510 and have phoned 3 (provider) and they have said there has been a problem with software and because their software is not compatable with my Applemac...
i'v got the same problem! i have the same phone and on 3 and a couple days ago it said ''no network coverage'' but it works fine when im out the house and down the road its just when im in the house. i asked them and they said it could be a temporary thing to do with the weather.
Oct 19, 2009 | Sony Ericsson C510 - Pay Monthly Cell...
No network coverage?!
OK i have just fixed my W995 that also came up with No network coverage out of the blue. Also when i went to charge it it said i needed a SE battery.
All this problem is, software. Yes simply all your phone needs is a software update. Sony Ericsson are known for disconnecting peoples phones if they do not have the latest software.
Go to http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w995?lc=is&cc=is
Should solve your problem. It did for me:)
Aug 13, 2009 | Sony Ericsson Walkman® W995 Cell Phone
Mobile is Showing No Network Coverage
You havent mentioned your model and series..i thnk your network part is gone..take d phne to the service centre immediately
Feb 28, 2009 | Nokia N72 Cellular Phone
There is no network coverage in my mobile (nokia 7610). If i go for manual search for operator selection it results in "no operator found". But if i put the same SIM card in any other mobile then there is...
If searcing manually say no operator found,it means any problem with receifer in your phone,for 2-4 scnd (than operator not found)check antenna and its connector.for 5-7 scnd check switch antenna. for 8-10 check RF IC. for 10 scnd up Check UEM(power IC) and CPU.But for safely do a software repair with a good PM.
Jan 27, 2009 | Nokia 7610
No network coverage
contact ur network provider. If stil it doesn't work Try changing the software.......If neither of them works try checking signal reciever in ur mobile....... If all the above doesn't work try replacing the unit.....
Good luck!!!!
Dont foreget to rate this.......
Aug 21, 2008 | Nokia 3120 Cellular Phone
No Network Coverage
reflash the phone and see if that fixes it....or upgrade the software
DESIREE - so you will need to take it to a mobile service center to have the board diagnosed to fix the network problem.
Jan 29, 2008 | Sony Ericsson W300 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
41 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
