Question about Eiki LC-XB15 Multimedia Projector
EIKI LC-XB15 power led blinking red, fan stay accelerated and no image projected.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Broken lamp or ballast unit
both are costly
Posted on Apr 17, 2014
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
projdoc
  • 2237 Answers
SOURCE: Eiki LC-XG110 lamp going off
the lamp may be at the end of it's life.
Posted on Nov 18, 2009
projdoc
  • 2237 Answers
SOURCE: EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
stecon3248
  • 57 Answers
SOURCE: plug in and green light
Check the lamp. If it is not blown then there is a problem in the lamp ballast circuit and the projector will need to be serviced.
Posted on Aug 15, 2010
Eiki 7070 CD player Cassette Tape Recorder
you could short out the wires that connect to the door close switch or replace the switch.
May 19, 2014 | Eiki LC-XB15 Multimedia Projector
Eiki 7070 CD cassette
probably dirty switch contacts, or interupted wiring
I have an eiki lc-xb42 that i just mounted upside down. how do I convert the image upside down?
in setting menu choose the icon with the upside down R ,press select and
with arrow keys select ON, picture shuld be OK now. No need to safe just press MENU.
Nov 12, 2010 | Eiki LC-XB15 Multimedia Projector
Giving message on laptop that says, "projection mode disabled"
try to use a full wired VGA cable, so the laptop can recognize the external display/ projector by the ID pins.
Many laptops deactivate external display ports to save energy
Mar 18, 2010 | Eiki LC-XB15 Multimedia Projector
I have an eiki xbl20 projector that i mounted upside down. How do I get the image to turn right side up?
Nov 20, 2009 | Eiki LC-XB15 Multimedia Projector
NO POWER
sounds like a heat sensor or fan problem. How old is the lamp, lamp hours etc.
http://www.youtube.com/watch?v=HvZ2DlVJ790
http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Sep 09, 2009 | Eiki PowerHouse LC-X4LA Multimedia...
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Won't power up
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
Eiki LC-XB15 Multimedia Projector Logo
607 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
