Question about Frigidaire Freezers
I have an error code on my upright frigidaire freezer "CE". it holds the temp but this error code keeps flashing. how can I get rid of it?
    New Friend:
I just unplugged mine and plugged it back in. It works fine now. The problem happened after a quick power outage.
Posted on Sep 04, 2015
watugot
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
SOURCE: my freezer temp.warning light has come on and wont cool anymore.
freezer temp light stays on
Posted on Jun 25, 2009
  • 389 Answers
SOURCE: CE flashing in the temp window of upright freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 523 Answers
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
Posted on May 06, 2010
  • 121 Answers
SOURCE: Temperature alarm is on on
i would make sure that the coils are all clean, inside and out. make sure the fan runs on the back, the water pan isn't over flowing.
Posted on Jun 25, 2010
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire freezer ce error
That is the temp sensor and should be hooked up to the board.
Oct 10, 2013 | Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Beeping coming from freezer
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
871 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
