Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Unit is leaking at the bottom of the door on both sides, it has been leveled and we are using correct detergent.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
54e6658
Posted on Sep 29, 2010
Leak in bottom of machine
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Bosch Dishwashers
Tip
How to repair or fix a Dishwasher if it leaks water
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loaded dishes. Leaks from the door itself may be caused by a faulty door gasket or faulty door tightness adjustment.
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for a repairperson.
An older dishwasher may have become corroded at the bottom, but this is a fairly uncommon problem. However, if this is the case with your dishwasher, it’s definitely time to invest in a new one.
on Sep 03, 2010 | Dishwashers
I have water leaking from bottom of dishwasher motor area..the dishwasher started making a whinning sound and then washer cycle would'nt work. it happened after i discovered a broken glass in washer.
Hi
Thanks
Rylee
Dec 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Leaking at the bottom of the door. Should I replace the gasket. ModelLDS5811ST
Hi
Thanks
Rylee
Dec 05, 2009 | LG Dishwashers
The top draw has a small leak in the back. Its about 5 years old. How do I pressure the lines to find the leak?
Hi
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks
Rylee
Hi
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
No water is coming out
boss let me help u......If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
please do rate these solution helpful. cheers!!!! Gizokieth
Aug 28, 2009 | Dishwashers
My Maytag washer leaks at the door. It doesn't
Rate the solution..
Jul 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Dishwasher leaks
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
91 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
