Question about LG WM-2277HW Front Load Washer
My washer is not finishing the cicle shows LE the screen
    President:
  • 1,382 Answers
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Posted on Jul 30, 2010
I have a problem with a f02 error
The washer is not finishing the cicle and is showing error f02
Aug 03, 2013 | Maytag EPIC MFW9600S
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
It shows a LE code
Hello.
The code showing at the front of the screen of your washer means the below explanation.
The L means LOCK and while the
E means ERROR.
However what the washer is saying is that you need to lock up the door of the washer properly then the problem of the LE will be solve .
Thanks.
Nov 08, 2011 | Washing Machines
Is not want to star the cicle. and apper the letters "le''
Hi
Thanks for using FixYa. The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. To resolve this check the wire harness connecting both of them and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG WM-1832C Front Load Washer
My washer says LE and hasnt drained all the water
I have the same issue - Had this washer for 6 yrs - up to now - it's been great. But, now I'm not sure what that problem is. Looks like the bin only spins counterclockwise - not clockwise. I can hear the motor trying to spin - then eventually I get the LE error code.
Dec 06, 2009 | LG WM1812C Front Load Washer
Error E10 means what , on the screen shows this error in any cicle you use to watch
I;M NOT 100 % I THING IS A CODE FOR BORD TRY TO UNPLUG THE WASHER FOR 2 MINT AND PLUG BACK IF IT DON;T STAR YOU WILL NEED A TECH. TO GO OUT AND CK FOR HOMS AND MOTOR AND ON BORD.
Jul 16, 2009 | Frigidaire Affinity ATF7000E Front Load...
My washer machine model #2494230 elite only work
your machine need to hang out in better circles...only kidding...it sounds like your selector switch (timer switch) is defective and needs replacement.
Apr 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
107 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
