Question about Hotpoint Refrigerators
I just moved into a rental condo and it has a hotpoint refridgerator. I noticed there seems to be water on the inside in the drawer and the shelf on top of the drawer. I dried up a couple days ago and I noticed last night there seems to be more.
  • 4,793 Answers
Refrigerators are not frost/condensation free,any shiney surface will collect it.......
Posted on Jul 29, 2010
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice is forming on inside of bottom shelf of hotpoint freezer FZA 51. Noticed this when trying to put bottom drawer back in and it was obstructed by the ice.
You have a drain that is plugged for the auto defrost. Instead of the water going where it is supposed to it's draining into the bottom.You need to find the drain and clean it out.Try getting the ice out and then look way in back and on the bottom for the drain.If you can't get to it that way you may have to pull the refrig out and see if you can get to it from the back.
Jun 04, 2011 | Refrigerators
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Water is pooling in the bottom of my roper refridgerator.
check door gasket all the way around , check water line inside frige behind crisper drawers
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice Sheet on floor of freezer
Check nothing is holding the door ajar, and that the door seals are closing properly all the way round. The abnormal thing about abnormal ice buildup isn't the fact that it's frozen - it's the fact that the water is getting in. The only way water is going to get in without you noticing it is in the form of moist air - and the biggest, most regularly disturbed way in for moist air is the door and its seal. A.
Feb 24, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
123 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
