Question about LG DH404E Dehumidifier
Can a hose be attached to the LG 45 dehumidifier to allow to drain as it fills?
    President:
  • 670 Answers
Yes a hose can be connected to this unit.
1. Remove the drain-hole cover from the back of the unit.
2. Connect a garden hose to the threaded hose connector.
3. Push the hose connector tightly to the drain-hole on the back of the unit
This is explained on the manual on page 12. Hope this helps
Posted on Jul 29, 2010
Fill light on and beeps but holding tank is empty
If it is like mine, the plastic part attached to the float in the collection bucket is broken and no longer actuates the switch that indicates the collection bucket (holding tank) is full. When I checked several years ago, the replacement part was no longer available. I used tape to keep the switch in the position that allowed the dehumidifier to operate and attached the hose connector to allow the condensate to drain. The collection bucket isn't needed anymore with this arrangement.
Oct 24, 2012 | Maytag M7DH65B2A Dehumidifier
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
My direct drain connection seems to have quit working. The drainage bucket fills rather than the water exiting the drain hose.
The line may have "gunk" built up in it. I would suggest checking the drain line to make sure it is not blocked.
Sep 10, 2010 | Haier 45-Pint Dehumidifier
Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
May 04, 2010 | Whirlpool AD50USS Dehumidifier
Not draining to hosue
Frequently, you have to make a hole in the bucket to allow the water to get out of it into the drain hose.
Apr 15, 2010 | LG LD65EL Dehumidifier
Where to hook up drain hose
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Sep 29, 2009 | LG LHD65EBL Dehumidifier
LG Dehumidifier overflows when attachment tube/hose attached
  • After 1 year of wondering why the LG instruction manual said no more than shove the white hose connector piece into the rear of the unit until secure, and relying on 'hit or miss' that the drain hose would actually work, (rather than filling up the bucket), I have finally found the solution. Ironically, it came while I was on my knees getting serial number from behind the bucket before they would try to help me by phone. There I saw it! The black interior drain piece inside the unit (top right when you remove the bucket) that the white house connector must be secured over. (Nothing in the manual ever told me to look for this.) As for securing the unit in the back--under the big vertical flap (which must point up and remain outside the unit), there is a smaller flap or triangular piece. They say that should be inside the unit, which it doesn't seem to go, because it is parallel to the large vertical flap), but if you push hard enough it does click onto the unit, while allowing the large while flap to remain outside (with the arrow pointing up), making the entire piece secure. Check once more to see if the white hose connector piece is secured over the interior drain piece (a black plastic elbow piece, on the top inside right where you remove the bucket, as I've said), and you'll be good to go! LG should be ashamed of their manual writing on this and the time I wasted getting my two units to work. However, at least these units are not fatally flawed as I was beginning to think.
May 19, 2008 | LG LD65EL Dehumidifier
LG DH404E Dehumidifier Logo
349 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
