I have a Hp Pavilion m8530f pc that stopped working yesterday. On startup diagnostics it said that it could not find internal hard drive. After calling HP Support, I was told that the hard drive probably went out and needed to be replaced (it was a Seagate Barracuda 750GB that came w/ pc). I purchased a new Seagate Barracuda drive (computer out of warranty) that had 1TB worth of data and tried to install today. After reattaching the power and sata connections I powered on the new drive. The computer initially found the drive but I powered off to load the system recovery discs that I had and now once I repower the pc the new drive no longer registers. I was running Windows Vista 64 (and the recovery discs from HP should reload the software), but now the pc does not find the new drive I just installed. Has anyone else had this problem?
    Brigadier General:
  • 3,917 Answers
Hi
The problem is when you have loaded the system recovery disc; the new hard drive got uninstalled or corrupted. You need to freshly reinstall the new drive . Hope that will solve your problem.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 29, 2010
  • cdole678 Jul 29, 2010
    I have unhooked and rehooked the sata cable from the motherboard and the drive itself several times (always w/ the power off of course). I have also tried using different sata ports on motherboard and I can not get anything other then the Reboot and Select proper Boot device error on the screen. I have also tried removing and reattaching the power connection to the new hard drive. What else do I need to do to reinstall the new drive?
    I have tried detaching and reattaching both the power connections and the sata connections to the new hard drive. I also unplugged and replugged the power cables into the drive. What else do I have to do to reinstall the new drive?
My laptop is showing the smart hdd error at startup. how can i disable that message? I am using hp pavilion 2000 laptop.
The SMART hard disk check has detected an imminent failure. To ensure not data loss, please backup the content immediately and run the Hard Disk Test in System Diagnostics.
Hard Disk 1 (301)
F2 System Diagnostics
ENTER - Continue Startup
For more information, please visit: www.hp.com\go\techcenter\startup
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
Sep 02, 2013 | HP 2000-2B89WM Intel Core i3-2328M...
I have an hp pavilion a320n desktop and once turned on it boots through the bios and then stops leaving a cursor blinking in the top left corner
Have you tried your onboard diagnostics? Stop the boot process after your machine boots through the BIOS, with F12 (I believe) You want to get to the boot menu. There you should see diagnostics. Run that.
The other possibility is a bad hard drive. You can test it with the onboard diagnostics. The easiest way to do it is to get into your BIOS and have a look at your boot devices. Your hard drive should be the first device.
Apr 17, 2012 | HP Pavilion a320n PC Desktop
I can't open my dvd drive on hp pavillion m 8530f pc desktop. Drive is visible by computer, can't find the little paper clip hole to open the drive physically
There should be a flap door on the outer casing, use your nail to pull down the flap from top, this should expose the internal dvd drive, now insert paper clip in the hole to pop the door open and pull out.
Sep 03, 2011 | HP Pavilion Media Center m8530f...
My hp pavilion dv 9500 notebook pc stops working at once since last two weeks. when I go to bios setup>diagnostics it gives me error 10008 and adds that replace your hard disk. In case that I work on...
for now as a quick solution take it to the service and install a new hard disk, install windows from the recovery disks and get your pc working again. install acronis home 2011 (am using it and its a savior) and backup your system. after doing all that take ur failed hard disk to an expert and try to save ur info.
May 16, 2011 | HP Pavilion DV9500T Notebook
M8530f will not startup!!
try restoring it to previous dates by going in accessories folder and then system restore
Apr 14, 2010 | HP KT334AA Pavilion Media Center M8530F...
Every time I turn on my new PC I get a black screen with writting on - it says Boot Device Not Found Please install an operating system on your hard drive Hard Disk (3F0) F2 System Diagnostics for more...
I have the exact same problem with my HP HDX 16. I would suggest calling the HP techcenter and exlaining the problem to them. Chances are they will want to take a look at it and will possibly replace your laptop. I haven't yet done this, but have allowed my computer to rest for a while. Leave it shut down for maybe 30-60mins and then try rebooting. Hopefully you will atleast be able to start it in safe mode with command promt. Open the command promt as the administrator and type CHKDSK which will perform a check for bad sectors in the hard drive. Hope this helps. otherwise give HP a call :)
Dec 14, 2009 | HP Pavilion dv6000z Notebook
HP KT334AA Pavilion Media Center M8530F will not POST. No beeps or monitor activity. Fans spin and that's it. The system froze and I had to manually shut it down, now nothing. Monitor works on another...
hello, below are few trouble shooting steps you can try.
1: open up the tower case and reset BIOS by removing the battery from the motherboard and switching jumper position. try turning on computer.
2: remove RAM sticks from the PC power on PC see results for any change, if no chnage stick one stick back at a time(if you have more than one) and then try it again.
post your results back and we will look to further troubleshoot the issue.
I hope this helps
regards
Amar Sondhi
Dec 05, 2009 | HP KT334AA Pavilion Media Center M8530F...
I bought a HP Pavilion ze4300 laptop and it has Windows XP on it and it was working fine for the past three weeks. Yesterday I started it up and am getting a message: ''Operating System not found''. One of...
It could also be the conncetion came loose, which can happen with IDE hard drives if the laptop gets moved around a lot. Remove the hard drive and take it to an electronics store to have it tested, or if you have a friend with an external enclosure (2.5" IDE interface, they cost between$10-20) you can hook it up to another computer via the USB port
Sep 25, 2009 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
