Question about Mitsubishi VS-60111 60" Rear Projection Television
Hi, I have a mitsubishi 60inch hdtv with the 3d which I bought about 1 1/2 years ago and it won't come on. Sometimes pushing the reset button over and over it will come on but when you turn it off and back on the next day it won't come on again. The light for the status is red and when you push reset the light for timer is green for about two minutes then back to red status. what is it? It happen about three times before and would come on after about 20 minutes reseting it and turning it off but now it won't come on at all and the light for lamp has never come on that I can see. What do you think it is?
  • walkingliber Jul 29, 2010
    it is model # WD-60735 and I notice that sometimes when you reset it it goes back to status but just for a second the green light for lamp is on then it goes back to red status. I should'nt have any problems already since I bought this from QVC in july of 08.
  • 11,896 Answers
This is likely either a power board failure issues due to bad capacitors or possibly a flyback issue. I would get a hold of an analog meter and do some testing. Each component has it's own power rating imprinted on it.
Posted on Jul 29, 2010
  • 1 more comment
    I also want to mention that before this happen we heard a buzzing sound like an insect a few days earlier. Like I said no picture or sound just the status light red and the timer light when you reset it for a few minutes before going back to status.
  • Nate Stansfield
    Nate Stansfield Jul 29, 2010
    These new Mitsubishi tv sets are known to have many problems. I see more problems with these than any other tv sets. The power boards and/or flyback, mostly power boards have been failing quite quickly
    so after hearing what I am describing, what do you think it is...the flyback or the power board ect. and also about what does it cost for either one of these not counting labor cost.
  • 10,594 Answers
This is problem of few leaky capacitors in dm board and/or power supply board, these capacitors will be replaced to fix the problem.
Please confirm is it Mitsubishi model VS-60111 tv or any other model?
You may need local tv repairman to replace leaky capacitors if you have no experience of parts replacement on circuit boards with proper tools.
  • Shahid Electronics
    Shahid Electronics Jul 29, 2010
    You could update without rejecting assistance, well, thanks.
I bought it 10 years ago but I used only once or twice. I went to used it but when pushing the start button it won't star
i would make sure batteries are good an with the batteries out look inside compartment and see if there any rust down where the batteries go if so try to scrape them clean
Aug 05, 2012 | Omron HEM-712CN2 cuff blood pressure...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Light flashing and tv won't turn on
you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-60111 60" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
