Question about JVC TH-A10 System
My JVC TH-A10 had a transistor burned I changed the transistor and got a new transformer... now only the standby light will come on... there is a cd in the drive and I cannot take it out and I cannot turn the unit on.
4 Suggested Answers
billynad
  • 51 Answers
SOURCE: Need service manual or schematic for SP PWA 10
http://www.fixya.com/support/p183860-jvc_th_a10_system/manual-17024/page-70
got there choose the right manuel for you i think you can download it you might need this software to read it www.adobe.com get adobe acrobat reader
Posted on Jan 18, 2008
SOURCE: JVC TH-A10
This unit only plays region specific material.
Posted on Jan 19, 2008
SOURCE: Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Posted on Mar 01, 2009
Power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
Oct 19, 2011 | JVC AV-24F704 24" TV
BLOWING FUSES INSIDE UNIT. REPLACE FUSE. BLOWS INSTANTLY
hello because theres a dead short and the fuse is doing it's job could be number of thing that are wrong. 1 shorted diodes/ 2 shorted output transistor/ 3 shorted resistors /4 blown or swelled capacitors get an engineer to check it out good luck
regards
shaun
Dec 27, 2010 | JVC TH-A10 System
I have a panasonic th-42px80u, i turned it on and there was a pop and a flash from the back of the tv. It will not power up and have no red light. ive taken apart and inspected power supply board for burn...
Look for a fried (possibly exploded) transistor or diode on the power supply board. In particular, look at the transistor mounted on a heat sink (metal radiator block) between the fuse and the largest transformer on the board. It may also have a damaged regulator chip driving it. Modern TV sets operated by remote controls generally have the power supply split into two sections - standby and main. Your problem is most likely in the main section.
A voltage sniffer won't tell you much - most sets have power right up to the fuse on the power supply board. If the fuse is blown, don't bother replacing it until you find out what blew it - you'll just waste another fuse. I generally start by doing ohmmeter checks (power disconnected!) on the diodes and transistors - anything reading less than 1 Ohm is probably fried or is being shorted through a transformer winding by another fried component. Other readings must be interpreted according to the circuit design.
Nov 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
JVC TH-A 10
Because you can switch the inputs between digital and analog. You can switch TV and DBS and also Tape and MD.
May 26, 2009 | JVC TH-A10 System
Sub won't power up
Nov 16, 2008 | JVC TH-A10 System
Won't Turn On
Jun 01, 2008 | JVC TH-A10 System
Jan 18, 2008 | JVC TH-A10 System
JVC TH-A10
Have the same unit and it does not have the capability to play anything other than commercialy produced CD's or DVD's i.e. no CD-R CD RW
Dec 25, 2007 | JVC TH-A10 System
JVCAV-N2043TV,Horiontal Output Transistor burns out everytime if fix a new one
Hi There,
The Hor Output transistor is connected to the Line Output Transformer. This transfromer provides a lot of voltages around your TV set but includes the very high voltage to the Picture tube...
These transformers are specially tuned to resonate at a certain frequency,
The Hor output transistor needs to match this frequency....so if the wiring inside the transformer is shorted by "just a bit" the picture will be visible but the transistor is struggling to match the transformer impedance,from the mismatched tuning...so the transistor draws more current from the power supply.. runs hot then burns out...
Usually manufacturers provide a Trip circuit that detects that an overload on the power supply is occuring and cuts the power to the Line output stage ...this is usually detected by a clicking sound within the power supply its called hiccuping.
If some one has altered the correct setting on the power trip circuit then the next thing that happens is the Transistor goes Blooooey like in your case.....
So to save you a lot of money replacing the output transistor
please replace the output transfromer as well next time...
But please... please... re-check the power supply trip circuit to save you a lot more expense in the future....
Best Regards From YUBEUT
Oct 10, 2007 | JVC AV-27230 27" TV
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
JVC TH-A10 System Logo
95 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
