Question about Troy Garden
Troy-Bilt 17.5-HP 42'' pony riding mower
Troy-Bilt 17.5-HP 42'' Tractor wont start using key.
key switch checked out ok with continuity check.
Jump starting doesn't work when jumped to battery.
will jump start with key in run position and jumped straight to starter.
  • 376 Answers
SOURCE: 14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
Posted on May 23, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 239 Answers
SOURCE: Husky ride on mower will not start.
Sounds more like a safety switch problem, first verify the seat switch then the mower switcher and make sure it's not in reverse.
Posted on Sep 04, 2009
Why wont my troy bilt 42 inch pony wont turn over i have changed the starter and it still wont crank what else could it be
jump the starer make sure it turns over if it does look for a bad safty switch just jump then as you find them eventually you wll find the bad one
Sep 07, 2014 | Garden
TROY BILT PONY CRANKS, BUT WONT START
carburetor is more than likely gummed up. you will have to remove carb and clean out jets. one way to check is to get starting fluid and spray into carb while someone cranks it and see if it runs. if it runs then the carb is dirty. and if it does not then check spark.
Aug 20, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy Bilt pony will not start
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
Nov 13, 2013 | Troy Garden
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Put a new battery on it and still wont turn over
Check all of your safety circuits: Drive safety, blade safety, seat safety.
Naturally, ensure that your key circuit is operating.
Gary
Dec 20, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Garden Logo
    291 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
