Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jul 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dl code - Whirlpool Duet GHW9150P Front Load Washer
Anonymous
Level 2:
New Friend:
  • Expert 171 Answers
  • Posted on Jul 29, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
171
Questions
0
Helped
26745
Points
309
FdL is a door lock error
Possible Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Kenmore top load washer 110.28102310
The DL error code is an indication that the door lock is having problems locking the door or confirming that the door is in fact locked. This is usually caused by a defective door lock assembly, wiring connection problem or the machine control board.Mar 9, 2009
Why is my Kenmore washer displaying a DL error code?
and more
https://www.google.com/search?q=Kenmore+top+loader+DL+error+code
2answers
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
1helpful
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
2helpful
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
1helpful
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
1helpful
2answers
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
