Question about Samsung DVD-VR375 DVD Recorder/VCR
I have a dvdvr375 that needs factory reset. How?
I have a samsung dvdvr375 that needs factory reset. It has the tv/vcr/dvd mode reminder stuck on the screen. I called samsung and they told me to press the up and down buttons on the unit simultaneously and it would go to factory reset. The unit itself doesnt have these buttons. Checked manual picture and no such buttons. Tried pressing these on the remote and did nothing.
    New Friend:
Press Program up+down button (on machine panel right corner) simultaneously about 5-10 sec - then you get factory settings back + many info lines about reseting (many lines different versions etc...)
Posted on Feb 22, 2013
  • Samsung Master
  • 8,457 Answers
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
Posted on Jul 29, 2010
Need the programming code for samsung dvd-vr375 thanks
Go to this site and put you make and model number in the search bar and you will be able to get the manual for your dvd player. http://tv.manualsonline.com/support/other/flat-panel-television/instruction-manual
Dec 17, 2014 | Samsung DVDVR375 DVD & VCR Combo Recorder...
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
MY SAMSUNG TV MODEL HCM5525W 55 IN IS STUCK IN TIMER MODE AFTER IT WAS UNPLUGGED. DO YOU HAVE ANY SUGGESTIONS TO FIX THIS PROBLEM?
You need to reset the tv to factory mode by pressing a code with the tv off,,,, mute--182--power and wait to see the menu appears on screen chose *reset to factory* press ok and wait until process done, them turn it on .
Dec 18, 2010 | Samsung HCM5525W 55" Rear Projection...
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Panasonic DVD/VCR player: ''Error'' message
Try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 03, 2017 | Panasonic Televison & Video
Parental password set by my kids no one fessed up how do I reset it?
  1. From a cold start with no disc in unit, press the / button simultaneously on the front panel for 5 seconds.
  2. All settings including the password will revert to the factory settings.
  3. Don't use this unless absolutely necessary.
Aug 21, 2008 | Samsung DVD-V6700 DVD Player/VCR
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
Samsung DVD-VR375 DVD Recorder/VCR Logo
3,035 people viewed this question
Jerry Greenberg
Jerry Greenberg
