Question about Lowrance XOG GPS Receiver
Lowrance xog would not display Navionics lake data or position.
I purchased a used Lowrance XOG to use fishing with
a 2010 Avionics Hotmaps Premium msd Canada Lakes card with no success.I updated software, but obviously missed changing an essential
setting, because I couldn't get any map image, and in Canada, even had Canada side of Rainy lake omitted, which was the only place I was! Do you have any idea what was wrong, and why I was unsuccessful?
Navionics site said xog was compatible, and I updated to 1.8 or 1.9, current one. I agree with all terms of use, except the subscribing to your service. If help here is not available for free, your invitation is untrue. Please help me if you can. I surely would appreciate it.
2 Suggested Answers
issikiki
  • 563 Answers
SOURCE: My new Endura out&back does
One thing that you need to know that the Fishing Hot Spots cards do not work currently in the Lowrance Endura Out&Back, Safari or Sierra GPS units as these cards are in SD format and the Endura's use microSD format.
A microSD version that will work in the Endura's with full functionality is being worked on.
If your new Endura does not work properly (dept of lake from Navionics...) after being charge (power on and off) you might have gotten a faulty unit. You should exchange it for a new one.
Posted on Sep 02, 2010
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Will the hds7 gen 2 read navionics lake map?
Yes, all Lowrance products will use and display Navionics map data.
Compatibility Guide America
Here is a link to the navionics compatability page so you can see which map cards will work in your unit.
Feb 03, 2015 | Lowrance HDS7 GEN2 Insight 83/200KHZ
Can you tell me how to operate a navionics hotmaps classic on my lowrance lcx16 ci?
It might be possible that you WILL NOT BE ABLE TO OPERATE such maps on your device.
A list of compatible plotters can be found here [in PDF format]:
http://www.fugawi.com/web/products/plotterfacts.pdf
Mar 06, 2011 | Navionics HOTMAPS CLASSIC LAKE...
Lcs-20c GPS slow with HotMaps Premium 09 card
Does the image come back by itself if you slow down or stop and wait? If not, make sure you are not leaving the coverage area of the chart you are set to. In the LCX-20, that Navionics chart is split up into several sections, if you have one section selected and are on the border and then leave that area, the map usually goes all white depending on your zoom level. If you are on a border like that you will have to learn to quickly switch the charts from the MAP DATA menu.
If the map does catch up when you slow or stop, and just can't redraw fast enough...
Make sure the LCX-20 has the latest updates which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
These updates often add additional Navionics support.
Most likely though, this is just going to be the way it is with that particular map and the LCX-20. If you zoom out it will be much much better. So if updating doesn't help, zoom out. Experiment to see how close you can be zoomed in while running above 20mph. If you can get a good zoom level to where the map can keep up and you can still see the information you need then you should be good to go. If not, use the LakeMaster card or go get a different mapping option...or upgrade your display unit.
Jun 24, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Lowrance HDS-5 won't load Navionics
You need to wait for a fix from Lowrance on the HDS units. Supposedly, a new software update is planned for May 15th 2009 to address this.
May 05, 2009 | GPS
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Apr 11, 2009 | Lowrance XOG GPS Receiver
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Lowrance XOG GPS Receiver Logo
95 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
