Question about Lexmark Z2420 Printer
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
    Genius:
  • 1,087 Answers
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Posted on Jul 29, 2010
Wifi light is orange
The colors of the WiFi indicator light show the network status of the printer.
  • Off means one of the following:
    • The printer is turned off or is powering up.
    • The printer is not connected to a wireless network and in power saver mode. In power saver mode, the power light pulses on and off.
    • The printer is connected to an ethernet network. Refer to the Quick Reference Guide to find out if your printer has ethernet capability.
  • Solid orange means one of the following:
    • The printer has not yet been configured for a wireless network.
    • The printer is configured for an ad hoc connection, but it is not currently communicating with another ad hoc device.
  • Blinking orange on the WiFi light means one of the following:
    • The printer is out of the range of the wireless access point (wireless router).
    • The printer is trying to communicate with the wireless access point but the wireless point is turned off or not working properly.
    • Either the configured printer of the wireless access point has been turned off and back on, or the printer is trying to establish communications with the network.
    • The wireless settings of the printer may no longer be valid.
  • Green means that the printer is connected to a wireless network and is ready for use.
Feb 02, 2012 | Lexmark Z Office Equipment & Supplies
Lexmark 6500 orange blinking light
  • The printer is trying to communicate with the wireless access point but the wireless access point is turned off or not working properly.
  • Either the configured printer of the wireless access point has been turned off and back on, and the printer is trying to establish communications with the network.
You may refer to these articles from the Lexmark website to fix the problem:- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Jan 24, 2012 | Lexmark Z2420 Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
My Lexmark Z1420 wireless printer used to work perfectly; however, since we moved, I can't get it to work. We have wireless internet. I have reinstalled the driver. I have checked the cables. I...
Your printer may need to be reset. Disconnect your printer from your computer. Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check for any paper jams or obstructions in the paper path and the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it.
When the printer turns on, reinsert one cartridge first. Close the cover. Check for any errors. If no error, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to reinsert a different known working cartridge to determine if the other is faulty.
For your wireless connection problem, you may need to reset the printer's wireless network settings first. Please refer to How to Reset the Z1400 and Z1500 Series Network Settings.
To reconnect the printer to your wireless network, re-launch Lexmark Wireless Setup Utility on your computer.
Jun 21, 2011 | Lexmark Z1420 InkJet Photo Printer
Wifi light flashing orange. communucation failed
The flashing light indicates that the printer is trying to connect to a network or is not connected to a network. This article Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products will help you identify and resolve the issue.
May 31, 2011 | Lexmark Z2420 Printer
How do i get my printer to work and stop the wifi button from flashing red? my internet is connected but the printer is not
Blinking WiFi light indicates that the printer is either trying to connect to a wireless network or not at all. Unplug the printer from the power outlet. Replug after 10 seconds. This will give enough time for the printer to reset. If WiFi light continues to blink, you may need to reset the printer's wireless network adapter. Please refer to this article: How to Reset the Z1400 and Z1500 Series Network Settings. The WiFi light will then turn off momentarily, then lights up solid orange. Launch the Lexmark Wireless Setup Utility to reconnect printer to your wireless network.
May 08, 2011 | Lexmark Z1420 Printer
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
What does it indicates when the wifi light is flashing red in the lexmax z2420
The flashing light indicates that the printer is either trying to connect to a wireless network, a "connection failure" or a communication is not available. This article should give you ways on how to fix wireless connection problems - How to identify a Wireless Communication Problem and Resolution Tips. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark Z2420 Printer
Blinking orange light where tghe wifi is
The light indicates that the printer's trying to connect to a wireless network. If the blinking wifi light has been going on for quite some time now but connection is still not going through, you will need to reset the printer's wireless network adapter. To reset the network adapter on Lexmark X6570, press Settings button > Network Setup > Wireless Setup > Reset Network Adapter to Factory Defaults. The wifi light will momentarily turn off then on and should be solid orange then. Try to reconnect the printer for wireless connection.
Jul 19, 2010 | Lexmark X6570 InkJet Printer
Lexmark Z2420 Printer Logo
1,214 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
