Question about A4tech PK5
This web cam has *installing device driver software*?
SOURCE: Web cam driver
Hi when i bought the laptop did not cd or softwear to drive my webcam now how you help me to bring the webcam in order to work please let no. Thanks Nazar.
Posted on Aug 28, 2008
  • 2567 Answers
SOURCE: web cam
1. Go to: http://www.a4tech.com/ennew/downloads.asp
2. Under the "Downloads" section, you will find 2 fields. Click the arrow next to the field labeled "SELECT" & choose "PK" from the drop-down menu. The second field will display "130MG". Click the arrow next to this field & select "5" from the drop-down menu.
3. Click the "GO" button.
4. In the next page: in the orange side-bar to the left you will find your web cam model & 2 buttons. Click the button labelled "Driver For PC". This will start the download of the installer for your web cam.
Posted on May 25, 2009
StevenPolloc
  • 28 Answers
SOURCE: i need A4 PK-635 web cam software installer
Download this and you should be fine: http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/A4TECH-PK-635.shtml
Posted on Jul 03, 2009
  • 6 Answers
SOURCE: i wany to install web cam driver without cd
Google your web cam manufacturer. You should be able to find and download a driver for your cam.
Posted on Apr 25, 2010
mace1mace
  • 1138 Answers
SOURCE: i need a driver and
Download this driver from this site
http://www.a4tech.com/download%20driver.asp?cmodnum=PKS-635K
or click this file and save it.
1. PK-635K
Posted on Aug 17, 2010
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Need web cam software
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 08, 2010 | GE EasyCam Plus Webcam
Can't get the web cam to work with IM messaging
Yes, all web cams are supposed to come with a CD where the drivers are. Usually drivers can also be downloaded from the manufacturer's website.
Aug 09, 2009 | Ezonics EZCam Webcam
Web Cam wont load
Uninstall the software for this webcam and then first install the software before connecting to the pc and then try connecting. Also install in a different location.
Thankyou
Jul 31, 2009 | Logitech Webcam
Software to install veo web cam
You can try this driver, as Veo’s web site is gone and there are few choices you have.
http://www.soft32.com/download_182173.html
Here is another Driver Database
http://members.driverguide.com/index.php?action=wizard_step_1
http://www.softsci.com/veodrivers.htm
or a direct link to the executable file... http://www.softsci.com/veodrivers/veo_330V_v002.exe
Sources: http://www.softsci.com/veodrivers.htm
May 26, 2009 | Veo Connect Webcam
I have intex it-305wc web cam but lost the installation cd.I want the software to make my web cam run.what should i do
i have intex it-305wc web cam but lost the installation cd.I want the software to make my web cam run.what should i do?
Feb 22, 2009 | Ezonics EZCam III Webcam
Web cam software
Hey, si necesita es que ayudarmentes "MKTECH JT-1000/SC-001A Dolwnload"
May 26, 2008 | Veo Mobile Connect Webcam
A4tech PK5 Logo
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
