Question about MGE Galaxy 3000 UPS System
I have galaxy 3000 merlin heron 20 kva ups, the problem is fault on rectifier & it gave sound continuosly beep sound. thanks, if i can get sercuit diagram i love it
  • 3 Answers
Where are you located?
Posted on Aug 23, 2010
Rectifier internal fault
check scr,check diodes,check driver cards
Aug 26, 2015 | MGE Galaxy 3000 UPS System
What coolant liquid use the MGE Galaxy 3000 UPS System 10 kva
What????? No coolant liquid is ever used in any type of UPS. EVER
Sep 04, 2014 | MGE Galaxy 3000 UPS System
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
APC SUVT 20 kVA power-up on batteries but not on mains
Dear If UPS working on MAINs but just not wakeup on MAINs then only 3 capasitors need to change.. for further you can diractelly contact @ techdata41@gmail.com
Nov 21, 2012 | APC Computers & Internet
Galaxy 3000 30kVA showns battery charge fault.beacause battery?
UPS battery must be tested individually before you can decide it is a battery problem or if charging fault can cause by defective rectifier/charger board.
Sep 09, 2011 | MGE Galaxy 3000 UPS System
Hi! Ive got "cooling fault" on my galaxy 3000. Can
hello
If this galaxy 3000 is of European Type ( that is having a radiator with coolant) , then after following proper BYPASS/Shutdown procedures, you could level the coolant in the radiator. You may require the tool kit that the supplier normally supply for this type of job.Generally the design was such that no evaporation could occur, however at times the top up is required. It may be as little as 20 (millilitre) Please check also the cooling fan just below the capacitor assembly. I hope this will help
Jun 08, 2011 | MGE UPS Galaxy 3000 UPS System
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Ups temprature fault
From what info you gave me. It sounds to me like it is either too small for the load, or it is in a confined space where heat is building up (UPS has to be outside of a desk office, etc.) or the rectifier is going bad and heating up. I would check to see if it does it by hooking up a small load to it like a radio or something, and if it is in the open, not overloaded then rectifier is bad,I see it alot. I am a Master Electrician and have worked on many UPSs'. Remember that if you keep a UPS loaded to it's full potential (which you shouldn't do) it will get hot. The rule is to only load it up to 80% of it's rating and you will be fine. To find out how many amps it will handle you simply devide the VA of the UPS by the supply voltage. Example: 1200va UPS supplied by 120v. is good for 10 amps. 1200/120 = 12 amps, then it is wise to add 25% more to the watts or amps when sizing them. Also, if it has a cooling fan make sure it isn't blocked by lint and is working, if it isn't working it will get hot fast. Good luck!
Nov 10, 2009 | MGE UPS Galaxy 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
191 people viewed this question
Top MGE Computers & Internet Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
