The power supply jack to my HP Pavillion DV1000 has stopped working. I believe that the problem is in the jack which fits onto the motherboard. Where can I get this done?
  • Alistair Johnston Apr 26, 2008
    Top stuff matey, thanks a lot. I will try to find a jack now, any thoughts about where?
  • 4,234 Answers
Anyone that can solder suface mounted components can repair this. You should see a local service shop. The hard part is getting to the component as the unit must be completely dis-assembled.
Dan
Posted on Apr 24, 2008
Letters keep typing even without keyboard
I'd try wiping and reinstalling the operating system or booting from a linux live-cd first to see if it's a windows issue or hardware issue. In the end though, yes I believe the motherboard is probably faulty.
Jan 22, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Pavillion dv1000 back light does not work
Well, I believe the reason why it isn't working is because:
The backlight only works when your at the dark or at a low light condition.
If not press "fn" and press the backlight increaser on the top of the keyboard.
Hope this helps!!
Jun 25, 2009 | HP Pavilion dv1000 Notebook
HP dv1000 will not boot, no power. Is this a hard
No Power at all sounds like the Internal DC Power Jack that is soldered onto the motherboard is bad. Send it to these guys www.generalsystemsconsulting.com
Mar 08, 2009 | HP Pavilion dv1000 Notebook
HP Pavillion dv1000 laptop will not power on
Cold solder on DC connector. Most common problem.
Feb 20, 2009 | HP (367799-001) Motherboard
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
HP Pavillion power link blinks
aa505 -
I can almost guarantee you this is an issue with the power jack on the laptop's motherboard. Even though it may not appear to be loose, its most likely the solder connection on the motherboard has broken, only allowing intermittent connection when the laptop is in /just/ the right position.
It'd be best to get this looked at sooner rather than later, preferrably if the computer is still under warranty. The connection will steadily decline, until the laptop is unusable.
Otherwise, let me know if you want to get rid of the system! I have a system, almost exactly the same model, that I need parts for!
Hope this helps!
-thinstatic
Jun 12, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
David Payne
David Payne
