Question about HP Officejet Pro8000 InkJet Printer
My HP Officejet Pro 8000 Wireless is leaking ink under the printhead area. This just happened as the printheads were 'sticking' between the ends of the printer and a wire came loose as I was coaching the printheads to the end. The wire favors a paperclip that someone straightened but I have no idea how to replace or exactly where it came from???? Can you plz help??
SOURCE: HP Officejet pro L7580 printhead
change the print head
Posted on May 19, 2008
Techvisitor
  • 63 Answers
SOURCE: The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Posted on Oct 31, 2008
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
ThiruBulls
  • 103 Answers
SOURCE: Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 27, 2009
PCTechOnline
  • 532 Answers
SOURCE: Printhead Problem:
Have you tried to replace the black/yellow printhead? This is not the same as the ink cartridges, but it is located in the compartment under and to the right of the scanner lid.
Here is HP's link.
Posted on Mar 21, 2010
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Hp officejet pro 8500 cleans printhead everytime i turn it on. and it uses ink! how cani deactivate it? how can i set to cleaning it manually?
That is quite normal . All inkjets run a cleaning cycle when turned on to make sure there is a good flow through the printhead and to prevent the head from becoming blocked. You cannot turn it off.
May 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Office jet pro 8500 alignment failed error message -black ink intermittently fails.
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
The following printhead has a problem black/yellow the printer will not print. These are new ink cartiladge
Hello and welcome to FixYa!
In the HP OfficeJet Pro L7780 the printheads are actually separate from the ink cartridges. In your case, it sounds like the black/yellow head has worn out and will need to be replaced. The good news is, this is a user replaceable part. The bad news is, the replacement heads are not cheap. Amazon has the HP 88 Black/Yellow printhead listed currently for about $61.
http://www.amazon.com/HP-Yellow-Officejet-Printhead-Packaging/dp/B000BO9L8M/ref=dp_cp_ob_e_title_0
YouTube has a nice video that explains how to install the printheads here:
http://www.youtube.com/watch?v=8Zl0LUxBSvg
I hope this helps!
Mar 02, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Will not print black...Joe
check the printhead.... print a print quality page from the settings button select print reports then print that page. there is a printhead health area as well as color blocks if there is streaks in the black yellow blocks or says poor the black/yellow printhead needs to be replaced. if it says good call hp for further troubleshooting and possible replacement under warranty
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printhead Problem:
Here is HP's link.
Mar 19, 2010 | HP Officejet Pro L7680 All-In-One Printer
Officejet Pro L7590 printhead message (printheads only 2m. old)!
Pull out the printhead from the computer and check the date under "warranty ends" If the warranty period did not lapse, call HP technical support and tell them about the problem. They will replace the printhead for free. I have gone through 3 black/yellow printheads and I received the replacement printheads via FedEx within 1-2 days. They will send you a pre-paid envelope to return via U.S. Postal Service via US Postal Service.
If the Warranty date on the printhead expired, then you may have to come out of pocket to replace the printhead since HP will argue that they are not obligated to replace the printhead since the manufacturer warranty lapsed.
If this is the case, check to see when you purchased the printer. If the purchase was within a year, the retailer (i.e. Best Buy) is on the hook since there is a 1 year implied warranty on products such as printers, regardless of whether the expiration date on the HP printhead expired.
Hope this helps
Aug 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro8000 InkJet Printer Logo
517 people viewed this question
Ben Johnson
